Separation Anxiety
Jim Wy
Jim Wy Posts: 64
Hey all:
Just wondering if there's a hard and fast rule about the distance/degree-of-separation between the mains of an entertainment unit from the Prime Seat (PS) for movies. I looked (under "search") for separation and/or distance but couldn't seem to get a definitive answer as to what should or shouldn't be, so I thought I'd just make life really easy for myself and ask:D
Quick FYI:
Mains= 50" ctr/ctr 24" up RTi28s
Centre= middle of mains CS175i
Sub= bottom left PSW10
pic attached (if I can)
JW
TV-_______Panasonic 50DL54
Receiver-__H/K AVR 330
Speakers-__RTi28s
Center-____CS245
Sub-______PSW10 (x2)
Surrounds-_FX300i's
Post edited by Jim Wy on
  • Jim Wy
    Jim Wy Posts: 64
    edited June 2005
    Post deleted...
    Speakers-__RTi28s
    Center-____CS245
    Surrounds-_FX300i's
  • aaharvel
    aaharvel Posts: 4,489
    edited June 2005
    Jim Wy I must say reading your post reminds me of a news ticker at the bottom of my television screen. =)
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
    F1nut Posts: 51,778
    edited June 2005
    You need to resize that monster before posting.
  • gregit
    gregit Posts: 284
    edited June 2005
  • Jim Wy
    Jim Wy Posts: 64
    edited June 2005
    Boy, and everybody says "bigger is better":D
    Howzat...better?
    PS Sitting 8'6" to 9' away.
    Don't forget you're talking to a total noob here. I could chat all day about the video side of things, DLP-LCD-LCoS, the new FOTV that's supposedly in the works (fibreoptic), rainbows, SDE, putting grey comb filters in your new LCD to increase the contrast ratio (warranty voider) getting into service menu to change the Kelvin output to make your TV look "warmer" (6500k-, definite voider for sure) blah, blah etc.. I'm even playing with my HTPC (bottom right under the speaker) to try to take the default 480p movie video and use my PC to rip and then upconvert it as a block to fill in the 2/3 pulldown to make it as close as I can to true HD. So far no go tho.
    What I've definitely noticed though is that audio is much more subjective than video. Video's easy. 480i<480p<720i<720p and 1:500 contrast ratio< 1:2500, therefore the numbers make it easy to see which is "better" and everyones on the same page.
    Done some searching on this forum. Two (or more) ppl can be talking about the same speakers. His mellow is your flat midrange, his deep base is your boomy, and his clear high-end is your tinny. See what I mean?;)
    Lots to learn... and lovin' it.
    JW
    Speakers-__RTi28s
    Center-____CS245
    Surrounds-_FX300i's
  • unc2701
    unc2701 Posts: 3,587
    edited June 2005
    1) Is there stuff piled up in front of your speakers? Move all theat crap someplace else... Even if it's not right in front of the drivers it'll mess with your sound.
    2) Ideal distance- Where you're sitting and the two speakers should form an equalateral triangle. So if it's 9 feet to the TV, the speakers should be about 10' 5" from each other.
    Backburner:Krell KAV-300i
  • Jim Wy
    Jim Wy Posts: 64
    edited June 2005
    Nope, nothing in front. Just have some air space under the left one (on some baffles) to equal the height of the right (on my PC). The wife's contribution (dog) is on my sub to the left of my left main.
    Thanks, that's all I needed to know. I knew there had to be some sort of formula to tell me the distance the mains had to be apart to give that "full-bodied" quality that people strive for without getting to the point that you can tell exactly where the speakers are.
    JW
    Speakers-__RTi28s
    Center-____CS245
    Surrounds-_FX300i's
    F1nut Posts: 51,778
    edited June 2005
    Get some real stands for the speakers. Don't forget to toe-in.
  • PolkThug
    PolkThug Posts: 7,532
    edited June 2005
    Move the sub to the front corner of the room. You'll gain spl's if you can "corner load" it. Make sure to give around 6-10 inches of breathing room from the walls.
    Regards,
    PolkThug
  • Jim Wy
    Jim Wy Posts: 64
    edited June 2005
    Thanks for the input, relocating stuff around as I type...
    JW
    Speakers-__RTi28s
    Center-____CS245
    Surrounds-_FX300i's
