SVS 25-31 PCi-for sale-local pick-up only
bignorm
Hello all you Polkies....
I have the following for sale-LOCAL PICK-UP ONLY
SVS 25-31 PCi
This sub is going to be two years old in Sept 2005 and is in perfect shape...Always used in a well calibrated system and has
NEVER bottomed out...
I have all original documentation, but NOT the original box..
Also I have the 22hz tuning port (currently installed) so you will be getting both the 25hz and 22hz tuning ports...
I upgraded to the 20-39 PC+
FOR INFO: visit SVS at www.svsubwoofers.com
LOCAL PICK-UP ONLY ..... $350.00 (or best offer)
I live in Lima, Ohio which is about 100 miles from most major Ohio cities....
SVS 25-31 PCi
Eliab/Dave Abrams calibrated Panny
Yamaha,Denon,Toshiba "in the rack"
Polks all around
SVS on the floor
Polks all around
SVS on the floor
Post edited by bignorm on
WOW! That is a good deal!!Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Wow! This isn't sold yet? Guess people aren't off work yet.
Good luck with sale.
