dented tweeter domes
edited June 2005 in Speakers
I just got my RT55's and both the tweeter domes are pushed in.
Will this affect the sound?
I think I can get them out again but I want to know if they should be replaced?
Thanks.
P.S. I searched to find this on the site and had no luck.
Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking
Post edited by Skynut on
Welcome!
    edited June 2005
    didn't someone say you can try a wine bottle vacuum?
    What I did on an old pair was I took the smallest needle I could find and gently pierced the material and pull out the dent.
    edited June 2005
    If they remain pushed in it will affect the sound. If they're badly dented, they may need to be replaced (which would be unfortunate, since I don't believe the tri-lams are available from Polk anymore -- the replacements are silk I think).
    If they're not too bad, you might have some luck pulling them back out with tape. Sometimes it works, sometimes it doesn't. It takes some pretty sticky tape to hold tightly enough. Some people say you can pull them back out with a vacuum cleaner-- I've never tried it. A small vacuum without a huge amount of suction, might be the way to go if you try that.
    Once pulled out, they should be okay. My 800i's tweeters were pushed in when I received them - long story- due to packaging. They both popped back out on their own, but one of them had a visible crease. Ken S told me that if they popped back out, they should be fine sound-wise. They replaced the one that had the crease, but the other one seems fine to me.
    Were they pushed in by fingers or by packaging?
    Jason
    P.S. ^^^ wine bottle vac might work. Good idea.
    edited June 2005
    I get the feeling it was done during packing, I am going to try a small vacuum pump to see if they will come out easy.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
    edited June 2005
    I used a vacuum cleaner on a pr of rti38 tweeters. They were display model, so no telling how long they were pushed in. Now you can not tell they were ever pushed. No effect to the sound of the speaker.
    Good luck.
    Rob
    mains: rt16
    center: csi40
    surrounds:fx 1000
    sub: SVS 20-39pc+
    edited June 2005
    I used a vacuum to pull out the dust cover on a woofer. I made a tube with my hand and put it over the vacuum so as soon as the woofer sucked out I could break the suction by opening my hand, that way I wouldn't damage anything. Good Luck.
    edited June 2005
    I used the Crevice Attachment (long narrow slot) on my vacuum when I did the tweeters on my rti70s. I gradually covered the tweeter with just enough of the slot to pull the dent out.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
    edited June 2005
    What is the fascination with poking dust covers anyway? I could almost understand a child, but when I sold electronics, I used to see grown men poking at them. I guess I was raised by parents that had an appreciation for audio gear.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
    edited June 2005
    I think people are somewhat retarded about fragile things like speakers.
    I know I did it once when I was younger and learned my lesson.
    Thanks for all the input, I was mailny worried about the sound quality after they are popped back out but I guess I will have to see.
    I am on my way home soon to try it out.
    Thanks again
    Sky
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
    edited June 2005
    I remember unscrewing the tri-lam tweeters and using my finger to push out the dome....per sid.
    suds, suds and more suds!
    edited June 2005
    Allright say what you will but I just put my lips on them and sucked. popped right out.
    It worked, now feel free to take the ball and run with it all you sick pervs.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
    edited June 2005
    Now that was an ingenious idea LOL :)
    edited June 2005
    Ken S from CS told me that trick, kiss the dent out :D is that where you heard about that trick? LOL
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
    edited June 2005
    No I was just soooooo happy to have them I just couldn't keep from kissing them. Then I just thought "What the heck, no one will know" and the rest is history.:D
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
    edited June 2005
    Just make sure you lightly caress the woofer and whisper sweet nothings into the port just so that the rest of the speaker doesn't get jealous.
    edited June 2005
    Woah. How do you know that wasn't a guy speaker you kissed?? :D
    Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
    edited June 2005
    It had a port hole in the front....duh I can tell the difference
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
    edited June 2005
    you can love your speakers but dont love your speakers
    edited June 2005
    ...and to think you guys laughed at me for massaging my tweeter. :D
    edited June 2005
    so what base is that in speaker terms? is a kiss first base? LOL and a carress like second? Man steve you were about to go all the way is she let ya..:D so lets say a kiss wasnt that bad at this point..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
Welcome!
Welcome!
