Questions regarding...Karaoke
Schris22
Schris22 Posts: 983
Hey guys,
Um.. First off this is a system for my dad.
Not that there is anything wrong with karaoke but just letting you know.
I had a few questions and hopefully someone can help.
First off what do I need. A microphone yes.
This would be running through my HT system which I believe is feasable.
Any other things I should look? My dad said something about a mixer but I have no idea what that is.
Do I need a special Dvd player?
thanks,
Chris
Receiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt
Post edited by Schris22 on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited June 2005
    Hello Chris,
    My knowledge about karaoke is fairly limited, but I'll tell you what I know. In most cases one of the components in the electronics chain has to be designed for karaoke applications. In other words, either the receiver or the disc player has to have been specifically built for that use. The Pioneer Company, for example, has (at least when I last looked) a very wide assortment of karaoke specific equipment. They had receivers, disc players, microphones, EQs, etc for this pursuit. They also produced a wide assortment of karaoke discs in all kinds of musical categories. Probably a karaoke receiver might be the first place to begin and try and find a knowledgeable Pioneer dealer in your area. Make sure your dad sees the karaoke scene in Cable Guy!
    Take care, Ken
  • Toxis
    Toxis Posts: 5,116
    edited June 2005
    You'll need to find a special DVD player that plays DVD-G (or is it CD-G??). Also, look into one with probably 2 mic inputs so you can duet with the ol' pops the next time Baby's Got Back comes on. It'll make for great fun. Then plug that player into your HT and you're good to start the festivities.
    EVERYBODY WAS KUNG FU FIGHTING!!!!!
  • hamzahsh
    hamzahsh Posts: 439
    edited June 2005
    I've a MALATA DVP-580 Multi-region DVD Player which has 2 microphone inputs and plays CD-G discs.
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
