Older RT series I's vs Non I's
I have noticed a lot of people like the "I" series speakers. RT55i, f/x500i, cs400i ect.
My questions are
1. What is the difference between the blue "I" series and the black non i series?
2. Other than the driver is there any difference? like the crossover or the tweeter?
Are the drivers interchangeable between say the rt55's and the rt55i's or the rt2000p and the 2000i
3. I am also wondering if they offered an RT5000i package.
I am just curious.
Thanks.
My questions are
I am just curious.
Thanks.
Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking
Post edited by Skynut on
The drivers and the crossovers were tweaked for an improved sound. It seems that the tweeters are the same though.
Physically, the drivers are interchangeable, but mixing would not be recommended due to differing T/S parameters with the different drivers. -
I was not thinking about mixing but just changing all drivers at the same time. Switching all to the blue or all to the black.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking -
Due to differences in the crossovers, the sound would probably still be off. -
Yeah, if you're going to change drivers, make sure you grab the correct xovers for those drivers.
How much of a difference this will make is somewhat subjective, but there is a difference. -
I remember reading about someone here taking a pair of RT55 and turning them into RT55i by switching the drivers and crossovers, but they said there was very little if no difference at all.
The crossover is different, that is what I was wondering about.
I have a pair of 2000p's and was considering adding a driver.
I was basically going to take a pair of RT55i's and install all the components into the 2000p box.
I hate to go through all that trouble and have them sound bad.
I would basically have to sacrifice the 55's. I would end up with an empty box and a couple of extra speakers.
I think the 2000's would sound alot better with the extra driver configuration like the 55 has.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Don't do that man! Don't mess up a perfectly good set of RT55i.
I am hoping to find a set with jacked up boxes.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Oh, ok then. I was about to have a stroke!
the "i" monikor stands for improved (according to the polk website) tweaked crossovers and something no one else mentioned- the i's are made of wood, not vinyl wrap. I've never actually came across rt's without the "I" label, but i'm not a polk speaker vet either.
So the company considers the "i" to be a better quality speaker than the non "i"?
Does anyone consider that true?
Does the RT5000i system exist??
Thanks for the info, no I must dig further for the answer.:DSkynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
NO, id keep them how they are.... I non I, whats the freakin difference? Not worth the change over and the cost of drivers.. Polk went from the regular to the ' I " series in a very short time... they basically went to real wood instead of plastic, and they needed another upgrade which was the I series... I don't doubt something was changed, but it wasnt drastic... IMO and FWIW that is
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
i agree the rt2000s need another driver but i wouldnt try to modify either speakers. the i seems to be brighter. i had both i series and p series speakers and i personally like the non i series better. the only way to tell is to have both and swap them out. it seems to me you just cannot find the sound you are looking for. you might want to reconsider your source the onkyo. also fyi polk usually has crossovers in stock as well ad the drivers if you wanted to change out a pair of rt55is to rt55s and vise versa. good luck. i never heard of a rt5000i series either.
I havn't heard of the 5000i either, I want the 2000's to stay as non i's but was just curious about the rest.
I want to get some 800's and see how they sound and I just bought the 55's. they have not arrived yet.
My next system upgrade will be an amp, I am pretty sure I want to get the Sherbourn 7/2100 and I think I will be happy for awile.
In the mean time I am just looking into possibilities.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking
