I made the ultimate sacrifice
  • brettw22
    brettw22 Posts: 7,623
    edited May 2005
    Listen whitie, rhyming or not, you best not have kids anytime soon......
  • rscamer
    rscamer Posts: 70
    edited May 2005
    Our cat has learned not to come in the theater room he will come up to the door and look in If he wants to be with the rest of us he just sits at the doorway.:cool:
  • Airplay355
    Airplay355 Posts: 4,298
    edited May 2005
    now i could come up with some great whitty remark for being called whitie but i wouldnt want to start anything. so :p
  • brettw22
    edited May 2005
    Well I don't know what 'whitty' is, but I'm sure if you wanted to show me your 'wit' you would have already done so......
    Maybe you'd like another round through the 12th grade? (special emphasis on spelling?) :D
  • warlocks1
    warlocks1 Posts: 1,263
    edited May 2005
    Thanks for all the input. I listened to the Infinity's for awhile this weekend and they sound pretty good. I can't take the grills off because the little ones love to push on the drivers. I can live with this for 4 months.
  • Willow
    Willow Posts: 11,223
    edited May 2005
    Apply 2 way very sticky tape on the floor around the speaker maybe 1ft diameter. As soon as the cat touches the 2way they will stop. There are alos expensive vibrating matts than you can lay infront of the 12's when the cat walks on it it vibrates and scares them.
