Software EQ for computer?
jarros
I'm trying to smooth out the frequency response with my existing computer sound system, and I'm looking for a software based graphic EQ. I'd prefer something with over 15 bands if possible, or possibly a parametric system. I'll be using TrueRTA to set it up once I find a suitable program. What do you use?
Thanks,
Jared
Thanks,
Jared
HT Setup:
Pioneer VSX-D912K
Polk CSi30 Center
RM6005 Satellites (Fronts/Surrounds/Rear Center)
Nameless 10" Sub
Pioneer VSX-D912K
Polk CSi30 Center
Nameless 10" Sub
Post edited by jarros on
What sound card do you have? Usually there is something of that variety that comes with the software included with the card.
I've got a Creative Sound Blaster Live. Yep, it did come with software, but the EQ section isn't as broad as I had hoped (I think it has 5 or 6 bands).HT Setup:
Pioneer VSX-D912K
Polk CSi30 Center
Nameless 10" Sub -
Thanks for the link, Maz! I finally got the software to work (after many, many reboots and a few ventures into Safe Mode). It's got a decent 10 band EQ that comes with the program, so now I'm just looking for something with a few more bands or a parametric EQ.
By the way, how's the Hi-Vi system going? I've got most of my parts ordered (except for the B3N's) and I'm starting to put the sub together. I'm trying a ported system for the sub tuned down to 27hz, so we'll see how that turns out!HT Setup:
Pioneer VSX-D912K
Polk CSi30 Center
Nameless 10" Sub -
Got both systems up and running and sounding good! I still haven't built the box for that Dayton 8" so let me know how yours turns out! I'm still using my cheap DCM 10" sub
I think what you are looking for is probably what is called a plug-in for audio recording software. The better software (i.e. more expensive) has good parametric EQ plug-ins included with the software. The less expensive software has more limited EQ. Probably the best/cheapest way to go is with a 15 or 31 band stand alone EQ unit. There are various manufacturers and price ranges as with everything else.
Good luck, Phil
5.1 Music rig:
SRS SDA front
2.3tls rear
2 cs400i center
Shure 12" sub
2 PSE mono blocks and 1 stereo amp front
2 PSE stereo amps rear
1 PSE stereo amp center
Mac 2100 bridged to mono sub
B&K ref 10 upgraded to ref 50 pre/pro
Harmon Kardon Citation tuner
Pioneer tuner for AM
Pioneer DA-45 universal player
Sony X7esD CD player
Technics 1200 TT
PSE pre amp for the analog stuff -
Good luck, Phil
It's sorta the same idea, although it's got to be able to render in real time like a seperate hardware unit would, rather than an effect that you can apply to a pre-recorded clip. Right now the KX project looks like my best bet, I just have to poke around a little more to see if I can find a plugin for a bigger EQ.HT Setup:
Pioneer VSX-D912K
Polk CSi30 Center
Nameless 10" Sub -
Some of the audio software such as Cuebase and other Stienberg products will process in real time. What is wrong with the hardware solution? I would assume that for sound worth listening to that you are using an external amp at least if not an external pre-amp too. What kind of speakers are you using?
Phil -
You might try looking at Guiter Center. They have computer hardware and software that blows away the nasty old soundblaster gear. They are also having a sale this weekend.
If there is a store close by, go to their pro sound department and ask questions. They have lots of neat toys. Even if you don't buy anything, it might be an interesting learning experience."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
You can also check out Musician's Friend on line - they are the same company as Guitar Center. If you call them they are usually very helpful.
Phil -
The only problem with using hardware is that, well, it costs more money. Right now I'm putting together a 2.1 system for my computer, consisting of Hi-Vi B3N's powered by a slightly-modded T-Amp and a Dayton DVC 8" with a 70W plate amp.
Basically I'm trying to get something to work that'll run in the background and won't use up a whole lot of resources, as I'll have it running all the time. I'm trying a few plugins from ANWIDA (the Graphic Equalizer and the Parametric Equalizer), but they seem to be hogging a lot of resources. It looks like the KX project should work, I just have to spend a bit more time looking for available plugins. Thanks for the suggestions, though!
JaredHT Setup:
Pioneer VSX-D912K
Polk CSi30 Center
Nameless 10" Sub
