Speaker wall mount recommendations for rear LS/FX surrounds??
lowridese
lowridese Posts: 1
edited April 2006 in Speakers
Hello, I have recently moved and now have my own basement finished for a real theater spot and i am mounting my LS/FX rears and i see all different types of wall mounts but i was wondering if anyone has any reccomendations? I see it is basically a screw hole on the back and maybe that might work best.
Thank you very much for help.
NEC LT 240K Projector
Comcast High Definition DVR
Onkyo TX-SR601 Receiver
Polk - RT 2000 Fronts
Polk - CSi5 Center
Polk - LS/FX rears
Post edited by lowridese on
  • amulford
    amulford Posts: 5,020
    edited May 2005
    Yep, that's what it's there for...
  • pearsall001
    pearsall001 Posts: 5,249
    edited May 2005
    I've got mine on 30" stands. They sound fantastic. Located on both sides of my room about 3ft dehind the sofa.
  • BMR
    BMR Posts: 9
    edited June 2005
    I too have the LS/FX rear speakers and have up until now used the freestanding floor stands made for these puppies. Since I am in the process of gutting/remodeling my (HT) room, I am also pondering mounting the speakers on the wall as well. However, it seems that I can't position a plate beneath the speaker since I must mount the speaker flush to the wall in order to use the small (mounting) hole. Does a person just pull wire out a small hole in the drywall at the spot where it gets wired to the speaker? Seems rather unprofessional. Any ideas/suggestions are welcome.
  • soiset
    soiset Posts: 724
    edited April 2006
    Are thread revivals ok?
    Anyway, I have the same question, with a twist:
    The LS/fx has a nice 3/8" machine screw tap in the bottom that would make for a great mounting point, if a suitable bracket were to be had. Has anyone ever used this mounting point?
