Polk RM20 vs RM6900 vs RM6700
I am looking at Polk speaker options for a Home Theater system. I am currently leaning towards either a Yamaha RXV750 or Denon AVR 1905 receiver.
Can someone explain the basic differences between the following Polk Speaker systems:
RM20
RM6900
RM6700
How do the speakers stack up against each other given that the prices are similar?
Thanks.
RM20
RM6900
RM6700
Thanks.
Post edited by rgordon on
all specs and literature are available for these systems here..
http://www.polkaudio.com/home/products.php?category=2
Good luck!! -
Denon > Yamaha. Go that route and don't look back. You'll be MORE than happy.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
^Psssh. Like you can say that at all without knowing what he's looking for.
AS far as 6900 vs RM20, I believe they are the same speakers, just in silver or black. And with the 6900, you get a side-firing sub instead of the RM20's front-firing.
The RM6700 is discontinued, so if find one, you should be able to get a good price. -
does anyone have any opinions on the rm20/6900? im interested
also, which bass is better, the rm20 or rm6900? their satellites are the same -
same overall freq response
is the bass with the 6900/20 better than the psw10?
