Atrium Speakers
I want to put Outside speakers in my garage. Our garage is unheated and we live in NW PA. I'm debating whether or not to get the Atrium45 or 55. I want good sounding speakers with good bass. Are the 55's that much better to warrant the extra cost or will the 45's do?
Post edited by shelshel on
We've owned the Atrium 55, it is in a garage that goes through cold and heat, and it pumps out plenty of bass (not ALOT or anything) and sounds excellent...
Excellent speaker. I have no experience with the 45.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I live in Warren County, NJ and have had a pair of Atrium45s mounted on my house, under the eves, for the past 3 years. I do not take them in or cover them during the winter months and other than a bird's nest being found behind one this year, they still look almost new. They are more than adequate for my modest backyard and the bass is OK, but I didn't expect subwoofer like bass from 4.5" speakers in an outdoor environment. Being mounted near 2 reflective surfaces (wall & roof of house) helps with some of the bass.Oh, you hate your job? Why didn't you say so? There's a support
group for that. It's called EVERYBODY, and they meet at the bar.
-Drew Carey
There is a very fine line between "hobby" and "mental illness."
-Unknown
My DVD Collection -
This is something else...I live in Warren County, PA! With using these 45's do you ever wish you would have gotten the 55's instead? -
No, the 45s are just fine. I got a great deal on them and couldn't justify the extra cost for speakers I'll only be using for about 3 months out of the year.Oh, you hate your job? Why didn't you say so? There's a support
-Drew Carey
-Unknown
My DVD Collection
