Don't know which Polks to get from my rear speakers.
lmpronto
lmpronto Posts: 33
edited May 2005 in Speakers
Hi, the room size is about 16x9.5.
For my rear speakers I'm looking at the rti4's and the fxi3's. I'm mostly going to use the setup for tv and dvd watching. I went to my local futureshop to demo them, the bookshelves just sound so much cleaner than the surround sound ones, but the guys say the fxi3's are the ones to get for dvd watching. What are your guys' perspectives. Thanks
Post edited by lmpronto on
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2005
    What are your mains?
  • lmpronto
    lmpronto Posts: 33
    edited May 2005
  • Willow
    Willow Posts: 11,233
    edited May 2005
    It would depend on how you will be setting up the rears
  • lmpronto
    lmpronto Posts: 33
    edited May 2005
    what do u mean?
  • PolkThug
    PolkThug Posts: 7,532
    edited May 2005
    If the surrounds are going to the sides of your listening position, get the fx's, if the surrounds are going behind you, get the Rti's.
  • Willow
    edited May 2005
    couldn't have said it better :D
  • lmpronto
    lmpronto Posts: 33
    edited May 2005
    well which way is better?
  • Willow
    edited May 2005
    Depends on if your room layout do you have side walls close by is your couch up against the back wall ?
    my couch is against back wall and I can't use the di-bi as I have patio doors on one side of the room and cannot hook anthing to that side. I use rti4 for my rears on stands. Not allowed (waf) to wall mount them above ear position.
  • lmpronto
    lmpronto Posts: 33
    edited May 2005
    http://img30.echo.cx/my.php?image=roomsetup4ay.png
    this link is a pic of my room setup. what should i choose
  • Joey_V
    Joey_V Posts: 8,600
    edited May 2005
    I would definitely get the FXi3 for surround.... especially in your case. Getting a bookshelf for surround is tricky - you must know how to position it right (behind the couch) whereas the FXi3 is more forgiving of placement.
    The only caveat with the FXi3 is the fact that it is not as good as the RTi4 with regards to multichannel music.
    But, in the end... I would still recommend the FXi3.
  • lmpronto
    lmpronto Posts: 33
    edited May 2005
    anyone else think i should get the surrounds instead of the bookshelve ones for my room setup?
    im in the position for $75 more to get the surrounds but like i said earlier, i just want to know the best for my room.
  • Frank Z
    Frank Z Posts: 5,860
    edited May 2005
    That is purely subjective.
    The only way to be certain is to audition the speakers your interested with your gear and source material, in your home.
  • PolkThug
    edited May 2005
  • Frank Z
    edited May 2005
    Yep,Yep,Yep.
  • Joey_V
    Joey_V Posts: 8,600
    edited May 2005
    How is it subjective? If the FXi3 were indeed as proficient with music as the RTi4, then why dont more people get the FXi3 as mains?
    Not arguing, just wondering...
  • Frank Z
    edited May 2005
    Apples and oranges. A Bipole/Dipole speaker is not designed to be a main speaker, it is designed to provide a diffused sound, and that is exactly what a surround speaker should do. Using a direct radiating speaker as a side suuround speaker will cause the surround channels to be highly localized, whereas a bipole/dipole will create a more seamless sound stage without localization.
  • aaharvel
    aaharvel Posts: 4,489
    edited May 2005
    since your system is for movies more than music- i would get the f/x's, put them on the side walls (the way they're supposed to be in a 5.1 setup) and use the dipole setting.
    if you're system is going to be based on music rather than movies- i'm still not a monopole fan for surrounds, but that's just me. I like bipoles for music, especially with SACD. Bipole mode provides a very nice middle ground between directional and diffuse.
    either way, the F/X's will let you choose between dipole or bipole at a flick of the switch. my layout is as follows:
    rti-4 front L&R
    csi-3 Center
    Fx300i white SIDE Surrounds (Dipole Mode)
    Fx300i white BACK Surrounds (Bipole Mode)
    hope this helps.
    (edit) i totally agree with Frank above my post.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Joey_V
    Joey_V Posts: 8,600
    edited May 2005
    Hence you agree that the RTi4 is better than a bipole/dipole speaker for multichannel music? I have always thought that multichannel music is served best with monopole speakers all across the room... surround is only good for movies. Atleast thats what I have always read.
    How can someone prefer a monopole for mains (especially for music) and not prefer monopoles for rears (when used for music as well)?
  • Frank Z
    edited May 2005
    No I don't agree with that assertion at all. A properly set up and callibrated surround sound system using bipole/dipole speakers will project a seamless soundstage with no localization. A direct radiating speaker located in accordance with Sony's placement guide for Multi-channel SACD playback is close, but they also recommend 5 identical speakers too.
  • lmpronto
    lmpronto Posts: 33
    edited May 2005
    when u look at my room setup, do you guys agree its going to be hard to perfectly place the right rear speaker if i get bookshelves?
  • okiepolkie
    okiepolkie Posts: 2,258
    edited May 2005
    I think the di/bi's would be better for your setup. It would be difficult to place monopoles and get a realistic surround image.
    Tschüss
    Zach
  • Joey_V
    Joey_V Posts: 8,600
    edited May 2005
    Wouldnt you say that the RTi4 and his mains RTi8 (i think... too lazy to scroll all the way up) are closer matched and more "identical" than a pair of bipole/dipole speakers? If so, then the monopoles would definitely be better for multichannel SACD. Wouldnt this be the same for DVDA?
  • Frank Z
    edited May 2005
    Since the FXi3's are timber matched to the RTi8's it all boils down to personnal preference. There's no middle ground, either you like the Bipole/Dipole effect or you don't.
  • Willow
    edited May 2005
    If you are in Ottawa I may be able to help
  • lmpronto
    lmpronto Posts: 33
    edited May 2005
  • Willow
    edited May 2005
    I have 4's you buy the fx, I bring 4 to your house take a listen I take 4's back you decide
