Sub Recommendation
dolfan87
dolfan87 Posts: 114
edited April 2005 in Car Subwoofer Talk
Well this is my first post. I have a 1970 Mach 1 Mustang that is just coming up on the end of a four and a half year customizing project.
The car is best described as a Pro Touring type vehicle, which I completely covered the interior in Dynomat Xtreme ....ANYWAY..
I am building my system, and currently own a "lightly used" W3 JL 10" DVC sub. I am not into massive bass ratteling my brains, but I do want the bottom end represented well.
I bought a C500.1 Polk monoblock, which will power the 10" fine, but my question is this; is the single ten going to provide a quality bottom sound, or should I step into a 12"? Dual 10"s?
If you feel I should change subs, which brands do you think have the best over quality of sound.
I will be using the Polk/Momo MMC525's both in the front and in the rear off of a C400.4.
I have the XM Alpine head unit running through an Eclipse 21010 EQ.
Again, I am shooting for pure sound quality, not 'Car-O-Bass'.
Thanks for your responses in advance.
87
1970 Mach 1: ///ALPINE DVA 9860 H.U and H701 processor. Image Dynamics CSX 52 components, and IDQ D4 Sub. Polk/Momo 400.4 and 500.1 amps.
Post edited by dolfan87 on
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2005
    Personally I like the Momo subs better than the W3. I think the Momos are smoother and sound deeper. I would recommend going with a single MM2124DVC and running it off the 500.1.
    That amp puts out 600 watts and the 2124DVC handles 400 per coil so that will be a good match.
    Badass car by the way! ;)
  • dolfan87
    dolfan87 Posts: 114
    edited March 2005
    That's kind of how I was leaning, thanks for the reply...anyone else have an opinion?
    87
  • neomagus00
    neomagus00 Posts: 3,899
    edited March 2005
    i kinda like mac's idea. if you want to look around a little more, i'm a huge fan of eclipse subs for sound quality. other popular contenders are diamond audio's new D9 subs, adire audio's brahmas, image dynamics' IDMAX (probably a bit more SQL oriented than you want) or the venerable w6v2 from JL.
    i like polk amps, i own one myself, but you may need something more powerful, depending upon the setup you choose. should you need a different brand of amp, look towards hifonics (supposed to be great for the money), usamps (use Internet Explorer to open), or RF .
    if i were to choose, i'd pick either eclipse or diamond, depending upon my mood that day, and i'd go with RF's Power or Type RF amps.
  • dolfan87
    dolfan87 Posts: 114
    edited March 2005
    Neo, thanks for the suggestions. I was up very late last night doing a ton of research. After careful consideration I choose the IDQ12 v.2 D4 12". I did this based on several opinions on different audio forums regarding Image Dynamics, and also the fact that my 500.1 wouldn't drive the IDMAX to full capacity.
    This seemed like a very good comprimise, and I got the sub brand new off e bay for $139.00.
    Now I just have to put the JL 10" on e bay to recoup some of my money, and off I will go. I will post pics of the car and install as soon as I get it finished.
    87
  • exalted512
    exalted512 Posts: 10,734
    edited March 2005
    its always a good day when somebody replaces a JL sub. The IDQ is one of the best sound quality subs on the market. very good choice, very good.
    -Cody
  • neomagus00
    edited March 2005
    so if idq is really good sq, what's the idmax for? sql?
  • dolfan87
    dolfan87 Posts: 114
    edited March 2005
    What I gathered from all the reading I did last night was that the IDMAX was pretty much one of the best subs out. However I would of needed 1000 watts for the one twelve.
    I am sure it would of been hella loud, with awesome SQ...I just would of been underpowering it.
    I missed out on a Polk DVC 12" by seconds for 98 bucks. I am happy with my decision though.
    87
  • MacLeod
    edited March 2005
    The IDQ is a SQ sub plain and simple. Used for modest installs and systems.
    The IDMAX is the balls to the walls sub. Its primarily an SQ sub but one that can handle 1500 watts so itll move more air than a wind tunnel.
    Id still take a Momo over the IDQ.
    Oh, and Cody.....
  • MacLeod
    edited March 2005
    j/k :p
    I just love these animated smileys!
  • Systems
    Systems Posts: 14,872
    edited April 2005
    I'm lookin for some subs to put into my friends 1987 bmw 325is and we are looking for some subs that hit, but yet don't cost a lot of money. Any suggestions?
    Testing
    Testing
    Testing
  • exalted512
    edited April 2005
    me v---v macleod
  • MacLeod
    edited April 2005
    Cody and Swerve!
  • denis87
    denis87 Posts: 86
    edited April 2005
    how are just the id's? i know the idq's are the next step up.
    www.dmbvideo.com www.oilfans.com
  • exalted512
    edited April 2005
    Image Dynamics has no slouches in their line up, they are all very good speakers. What kind of price range are we looking at?
    oo, and MacLeod and Swerve...
    -Cody
  • MacLeod
    edited April 2005
    WAAAAAAAAAAAAAAAAHAHAHAHAHAHAHA!!!!
    ROFLMFAL!!!!
    I cant top that one!
  • audiobliss
    audiobliss Posts: 12,518
    edited April 2005
    dolfan87 - Sounds like you found quite a deal on quite a sub. I would have liked to see you get a Momo, but you certainly won't be disappointed with that. Awesome car, btw. Let us know how all this turns out; I'd love to see the pics of when you're done.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • exalted512
    edited April 2005
    ROFLMFAL!!!!
    I WIN:D
    -Cody
