Non-parallel wall speaker placement
Aaron
Aaron Posts: 1,853
edited April 2005 in 2 Channel Audio
Has anyone tried positioning their speakers so they were not parallel to any walls in the room (corner placement would be the most common instance). What kind of results did you have?
Aaron
Post edited by Aaron on
  • Shizelbs
    Shizelbs Posts: 7,433
    edited April 2005
    Not sure if this is what you had in mind but...
    Mine are against the longest wall in the room. The right speaker is next to a fireplace that creates a diagonal between the main wall and the perpendicular wall to that. The left is on the main wall, with the next wall about 7 feet away.
    The only thing I notice is that the soundstage for the right is much deeper, wider, taller, and can reach me better than the left. Also it seems as though all music has been balance to the right.
