Today`s project
beardog03
beardog03 Posts: 5,550
edited April 2005 in Electronics
Ah! 4000 CDP upsampler baord and Power cord install..
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Post edited by beardog03 on
  • beardog03
    edited April 2005
    parts
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    edited April 2005
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
    F1nut Posts: 52,005
    edited April 2005
    Add some Dynamat while you're in there.
  • beardog03
    edited April 2005
    yep..!
    need some more for the bottom though..
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
    F1nut Posts: 52,005
    edited April 2005
    Excellent.
  • beardog03
    edited April 2005
    is it possible to upgrade the outputs ?
    or is it necessary ?
    The digital out seems to be broke (plastic)
    Balanced outs maybe ?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
    F1nut Posts: 52,005
    edited April 2005
    Sure, it's possible. Cardas makes some nice ones. As for the digital out, contact Kevin and I'm sure he'll send you a new one or remove it, plug the hole and forget about it.
    Balanced outs? Nah, it's not a balanced design, so no point.
  • beardog03
    edited April 2005
    thanks F1...
    Cardas outputs on the short list.. :D
    I`m just looking for a way to use the ones on my amp..!
    and I saw some nice I/C`s for a good price..!:rolleyes:
    not that I can afford any right now...
    besides..the pre doesn`t support them anyway..!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    edited April 2005
    installed...mucho more beefier..!!
    :D
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    edited April 2005
    board...
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    edited April 2005
    board after..
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    edited April 2005
    easy install...
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    edited April 2005
    the heat sink was the hardest to install, as it was a tight fit...
    she`s ready for a test run..
    I would like to thank F1 for all his help and input from cradle to grave on this project...
    He helped me locate this unit, and was a great help throughout the process....
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • Whadyasay
    Whadyasay Posts: 300
    edited April 2005
    I see that you used dynamat to line your player. I use similar sound-deadening material (used for car audio and inside speaker cabinets) to line the inside of my Denon 2200, as well as stick some pieces on the outside of the transport case. It helps quite a bit in vibration control.
    Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
  • janmike
    janmike Posts: 6,146
    edited April 2005
    Nice job. I have been looking to do some mods to my cpd. What thickness of Dynamat did you use and where did you obtain it from? Is that something that you put on the underside as well as the inside of the cabinet?
    Michael ;)
    NORTH of 60°
  • beardog03
    edited April 2005
    you can get it at www.partsexpress.com , crutchfield, or do a search in your browser..
    there is a lot of places that sell it..
    you can apply it to anything that may vibrate, as long as you don`t restrict airflow in any way you should be fine..
    now I`m just waiting for the killer I/C`s to show up..
    Got em from a great guy over at the `gon...;)
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
    F1nut Posts: 52,005
    edited April 2005
    Bear, looks great and you did a nice job with the step by step pics. How does it sound?
    Another source for Dynamat is www.thezeb.com. I like the Xtreme stuff best, but any of it is good.
  • DAGLJAM6
    DAGLJAM6 Posts: 635
    edited April 2005
    beardog, where did you source the tube dampers from and have you used the setup with and without them installed?
  • beardog03
    edited April 2005
    F1...
    got her powered up and tubes warmed up
    no flames shooting out , so it looks like I did it correctly..!!!
    actually It is a pretty straight forward upgrade/mod..
    even I could do it..!!:D
    I have the NOS JAN Phillips 6922`s in the pre amp...
    MAN...this system amazes me everytime I turn it on...
    The music has a crystal clear sound with the killer tube sound mixed in..
    out effin standing..!!!
    The LSi9`s seem to like this player/system...
    may be my imagination, but it seems more powerful...more full..
    I love it bro...thanks for the help/tips...
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    edited April 2005
    DAGLJAM6 ,
    The upsampler kit came with a set..
    There were already a set in the CDP when I got it..
    I put the new ones on the Dodd tubes..
    It seems to tame the "ringing" sound that I hear sometimes..
    You might try upscale audio and see if they have some..
    I think they are a good thing to incorperate into the tube set-up
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • DAGLJAM6
    DAGLJAM6 Posts: 635
    edited April 2005
    10-4, I've got a pair of 12au7's that do the "oscillation ring" thing great tubes otherwise.
    F1nut Posts: 52,005
    edited April 2005
    Originally posted by beardog03
    I love it bro...
    Hehe....that's all I need to hear and that's what everyone who added the upsampler has said. Enjoy!
  • beardog03
    edited April 2005
    digital clarity and the warmth of tubes..
    I ask you...
    what more could you ask for..?!!
    :D:D:D:D:D:D:D:D:p
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • DAGLJAM6
    DAGLJAM6 Posts: 635
    edited April 2005
    Not to steal your thread but, I remembered some old tubes I had stashed and ..lo and behold a pair of damper collars circa 1964-65
    pulled 'em off slid them on my 12au7's and great no "ring"
    I'll still check with Upscale 'cause they don't seem to detract from the sound other than the irritating ring.
    I wish that I could do a comparison with my Jolida CDP and an Ah CDP.
    With that additional upsampler yours should really sound sweet with well engineer cd's .
    Nice of you to show the upgrade in pictures ,always like to see the innards of gear.:cool:
    Dave
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2005
    Robert - Thanks for the goodies...you know I was joking right? I love them :)
    I have some tubes for you to try, freebies for you homeslice....email me and let me know what you currently have in your goodie box.
  • beardog03
    edited April 2005
    yep..!!
    my way of sayin "thanks"...
    you help me start a journey that put my head in a good place..
    kant thank you enough..
    I`ll go through my stash and see what I have...
    you and Jesse have help me put together a stellar 2 ch rig.
    mucho grassy **** (means many thanks in south of the border talk)!!
    :D:D:D
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • Early B.
    Early B. Posts: 7,900
    edited April 2005
    Looks great. I'm sure it sounds better, too.
    Two things --
    1. Has anyone ever tried using those peel & stick floor tiles from Home Depot instead of Dynamat? I don't know, but I heard they work just as well for a fraction of the cost of Dynamat.
    2. I bought some tube dampers off ebay a few months ago from a guy in Canada:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=50598&item=5765169507&rd=1&ssPageName=WDVW
    Don't know if they actually make a difference, but they look kinda cool.
    "God grooves with tubes."
