make-shift screen
Willow
This weekend, as part of my bday gift, we have acess to a DLP prjector. My question is what can I use for a screen. I thought of our walls but they are a light yellow and might off-some of the colors. What can we use that will give good results but cheap we are only using it for this weekend.
I thought of a big-a$$ white sheet from staples.
Post edited by Willow on
any-one ?
there is a 4 ft by 8ft plastic material that they sell at Home Depot (not sure if those exist in Canada). anyway, it's made by Parkland Plastics. It should cost less than $10. It's basically a big sheet of white plastic that is just under a 1/4 inch thick. You can read about it here:
AVS DIY screen section
I'm pretty sure Mazeroth is/was using a Parkland screen. maybe he'll chime in.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
thank you very much
