Optical network isolation
bikerboy
Hi
I've thinking about upgrading my pc streamer. I'm currently using a Sonore Ultrarender. I've been looking at getting an optical converter that receives the copper cat 5 signal coverts it to optical and sends it to the reverse conversation. Cleans up the signal. Trying to improve the sound quality of the pc using flac and wave files. My Shigaclone cdp sounds better when spinning a cd than the flac file on the pc. Small Green Computer is the distributor for Sonore and will probably get something from them. So many options so I'm not sure what to get. I think I'll send them message and see what they have to say. Anyone using optical isolation for their network signal?
Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w ONN Streamer, Sangean HDT-1X tuner
Vinyl: Nottingham Spacedeck->Pioneer PL L1000 linear arm->Soundsmith DL 103R w Contact line stylus->SUT->
Bottlehead Eros tube phono preamp
CD: DIY Shigaclone
CD: DIY Shigaclone
What DAC are you using with the UltraRendu? That is likely the difference you are hearing. There are many products that are used to isolate/cleanup Ethernet signals. @treitz3 has probably experimented with more varieties than anyone here.
I use and an Uptone Audio Etherregen.
https://uptoneaudio.com/products/etherregen
It's been discontinued and they've supposedly been working on a new version for the past 3 years. You can find them used.
Please explain more about what you want to do, not sure I understand why you want/need to use optical and why reversing it cleans the signal. Optical "typically" is the least best choice for digital transmission/conversion in audio.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
I use a Roon Nucleus One for a streamer and it's wired. My computer is close enough (in another room) that I can run an ethernet cable from my router to the Nucleus one. I use Qobuz to stream and the Nucleus One has an SSD which holds all my FLAC files. I use Roon via a 9" tablet to run everything.
Signal comes out of my PC --> Router --> Etherregen --> Nucleus One which is my rack then USB out to my Holo Audio Cyan 2 NOS dac, MIT Shotgun S1 interconnect.
The Nucleus One and Etherregen are both run with separate linear power supplies instead of the cheap switching walwarts.
Sounds fantastic and it's dead silent. I'm sure the Puritan Audio power conditioner helps too.
Are you talking about optical (TosLink) or optical Fiber?
Something like this?
https://www.smallgreencomputer.com/products/sonore-opticalmodule-deluxe?
I'm thinking of upgrading the Ultrarendu to the newer Optical rendu deluxe and a switch with optical fiber and copper rj45 output. Currently using Windows I7 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY connected to the network via copper cat 6. I'm not hearing any noise but feel like improving the quality of the pc files. We listen to radio the most, with files on the pc next. Vinyl is going away once I get all the records converted to wave files.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w ONN Streamer, Sangean HDT-1X tuner
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
I use a short (1m) USB cable from my computer to a box that converts the signal to optical. I run optical cable to my ER that accepts optical input via an adapter. Easy to do. Cost about a hundo, if I recall correctly: 2 adapters, converter box, length of fiber optic cable.
TP-Link Gigabit SFP to RJ45 Media Converter(MC220L)
(2) Finisar 1.25 Gb/s RoHS Compliant Long-Wavelength Pluggable SFP Transceiver FTLF1318P2BTL
12 Meter Singlemode Duplex Fiber Optic Cable (9/125) - LC to LC - Yellow
Thanks that's what I'm looking at! Did it clean up the signal?Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w ONN Streamer, Sangean HDT-1X tuner
CD: DIY Shigaclone
It was already very good, to my ears. I had been using a very good Supra Cat7 USB cable from my router to the ER. I recall thinking there was an incremental improvement.
Thanks for the comment on the improvement in sound. I decided to take advantage of bf. Sonore opticalRendu Deluxe kit on the way. It will replace the Ultrarendu. Hopefully this will up the PCs game. Happy turkey dayMain system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w ONN Streamer, Sangean HDT-1X tuner
CD: DIY Shigaclone
