SDA 2a Upgrades
Hello all!
First post here, although I've been observing from afar for quite sometime!
I recently inherited a pair of SDA 2a's from my father. In addition to being sentimental, they are great sounding speakers. I grew up on them, and always loved the sound.
Recently, I feel as though they have been missing frequency content. All of the drivers are moving air, including the passive woofer. But it feels like there might be some content missing in the 120 to 500 range- yikes!
My dad bought them in 86', and I do not believe they have ever been serviced. They have the original SL2000 dome tweeters, and identical MW 6510 driver pairs on each channel.
I've done some lurking on how to upgrade/restore theses guys, and think I have a pretty good grasp on the next steps, but I was wondering if anyone could provide some updated info. Most of those other posts are from pre-2010, and many of the shared crossover schematics are missing.
I think what I'd like to do is upgrade the tweeters to the RDO-194's, assuming those are still available. Recap the crossovers, after sourcing the components. I also saw talk of using dynamat behind the passive radiator, and would be interested in trying this as well.
I'd love any thoughts/suggestions on this project. I come from a concert audio background, but passive speaker modification is a whole new world for me. Eager to learn and get these things up to stuff. Also happy to provide serials and pictures, if that would be of any help!
    pitdogg2 Posts: 27,921
    I can save you some time, I have a set of SDA2a crossovers already recapped with Sonicaps and Axon poly caps and Mills resistors. they would be plug and play. All you would need to do is buy the RD-0194-1 tweeters.
  • turtleman559
    Hey Pittdogg, Thanks for the reply! I feel as though I recall seeing your name on those older forums. I appreciate the offer on the built crossovers, but I must admit that I'm pretty set on doing it myself. Especially given the sentimental value of the speakers, it's something I really want to dig into and learn from. As I said, I'm pretty new to this, and it seems like a fun project!
    I would be very interested to pick your brain about which components you used specifically, and where you got them. I've seen mention of the Sonicaps, Axons, and Mills- I plan to look into them next, now that I've found a crossover schematic.
    That said, if all goes south, I will certainly reach out about your crossovers. As much as I want to build these, I also want to hear them eventually!
  • dromunds
    dromunds Posts: 10,176
    If it were me, I’d look into PitDogg’s offer. There are two crossovers on each 2A speaker and it can be an expensive proposition to price all those caps and resistors. If someone has already done the work I would at least be discussing it with him. He’s a good dude. Rebuilt crossover offers don’t come up that often, especially for 2A’s
  • turtleman559
    dromunds wrote: »
    I just spent the last couple hours tracing the wiring diagram and specing out the parts, and I suspect you might be right.... As I said, a novice at work here!
    PM replied to @turtleman559
  • invalid
    invalid Posts: 1,560
    You can use the RD0198 tweeters if you add a 5.8 ohm resistor. @westmassguy has a thread somewhere on this site on how to accomplish it, I did it to my 2a's but can't remember where to place the 5.8 ohm resistor.
    F1nut Posts: 52,406
    invalid wrote: »
    It's a 5.8uF capacitor not a resistor.
    xschop Posts: 5,931
    Resistor, capacitor, inductor... It's like Ohm's law here at the CCP. Just crank up the Kraco dial 'till you get that 500wpc fix.
  • invalid
    invalid wrote: »
    Dooo, I knew that, been working in the rain in Florida the last few days, not really with it currently.
    F1nut Posts: 52,406
    invalid wrote: »
    invalid wrote: »
    So, you have wet brain. You're excused B)
  • invalid
    So, you have wet brain. You're excused B) [/quote]
    I came down to Florida from Michigan to do a roof and take a weeks vacation after, now I'll only get 5 days of vacation because it's been raining about 50% of the time.
    F1nut Posts: 52,406
    edited January 2024
    invalid wrote: »
    At least it's not snow.
  • DCskinsfan
    Does anyone have instructions for modifying the 2a blade/blade crossovers to 2b specs (pin/blade for use with dreadnaught isolation transformer) so I can use non common ground amp with 2A speakers? I've gotten confusing and contradicting info on line.
    F1nut Posts: 52,406
    edited August 21
    I'm not aware you can do that. The two models use different drivers, different inductors, different capacitors and different resistors.
    xschop Posts: 5,931
    edited August 21
    Just use the 2B crossovers with nom. 8 ohm MWs (6510 or 6503) on stereo circuit and 4 ohm MWs, preferably 6511, or 6502 on the SDA circuit.
    2a use 4 mw6510, and some rather large caps. Seems like it would be cheaper to just find some SDA 2b's.
    SDA 2a, correct you need a common ground amp, cannot use dreadnought.
    The 2a and 2b are very different critters.
    Which amp are you wanting to use?
