SDA
Pete77
What or the latest updates for my sda, sda 1, and sda 2 ?
Answers
You're going to need to give way more info?
SDA 1
SDA 1a
SDA 1b
SDA 1c
SDA 2
SDA 2a
SDA 2b
SDA SRS 2
SDA SRS 2.3
SDA SRS 2.3tl
So just stating SDA 1 or 2 is like saying i have a car, are there any updates? -
My suggestion: Take some time and read the forum. There are countless threads detailing upgrades at various price points.See profile for rigs. Nothing else here.
I would suggest you download the newest version of firmware for any SDAs over 40 years old. Then it would be safe to install patches and software updates.
This could take some time considering the wi-fi limitations of these old Polks. If you are lucky enough to have an original interconnect cable, you can use it to hardwire directly and greatly increase download times.
Make sure to de-select the box that says: "Add a soundbar to my system." -
What the hell kind of AI hallucination did I just read?2 channel: MXN10, Anthem MRX740, Anthem MCA5, SDA1c recap/RDO, JL Fathom F112V2, Tributaries series 8A, Tara labs RSC
Theater: Above plus Paradigm reference studio 100, Polk FX300i
Projects: SRS1.2TL, SRS 2, M5Jr+
Party/1st floor: iPad, Marantz SR5005, Paradigm reference S100v2, monster bulk cable
B&O H9 Gen3
