Audioquest Cinnamon HDMI 0.75m x4
dorokusai
dorokusai Posts: 25,625
I’m listing qty. 4, Audioquest HDMI 0.75m cables. It’s 2.5ft per cable. They’re as new but without packaging.
$125.00 shipped
Price is shipped for all 4 cables to the CONUS.
Perfect for clutter cleanup as I like to personally have the shortest run possible. Take that for what it’s worth
  • dorokusai
    Another photo
    billbillw Posts: 8,007
    edited July 17
    It might help to indicate what those are rated for since there are different versions of the cable through the years. A closeup of the plug should indicate. If it doesn't say 4K+HDR then I would say they are not a good idea for anything beyond 1080p which was the earlier HDMI 1.4 standard.
    pitdogg2 Posts: 27,684
    billbillw wrote: »
    Bill, do you mean 4K+ARC ?
    billbillw wrote: »
  • dorokusai
    Bill,
    Thank you for the comment. I only know that they just say HDMI, high speed w Ethernet. Where does that put it in regards to support? I have no idea.
    Mark
    They would probably be great for Blu-ray, cable box, audio, and other non-4K feeds. They might work with 4K, but could be hit or miss depending on handshake.
  • dorokusai
    That makes sense, thanks for the help,as I only knew they weren’t brand new.
  • dorokusai
    edited July 20
    A cleaner pic… more than willing to go w singles if you have no need for fourg0ylh1cly1j2.jpeg
