Oppo BDP-103 firmware update
steveinaz
in Electronics
Released: 23 Jan 2017
Version: BDP10X-83-1226
FYI
FYI
Fixes in this version:
Comparing to the previous Official release version BDP10X-83-0715, the major changes included in this version are:
Resolved an issue with gapless playback. (BDP10X-83-1226B)
Resolved a no audio issue with certain receivers when playing DD+ 5.1 content from Netflix and Vudu. (BDP10X-83-0918B)
Resolved an issue where the player would automatically power off when receiving commands via a TCP connection. (BDP10X-83-0918B)
General disc compatibility improvements based on recent and upcoming Blu-ray releases as well as user-submitted disc samples.
All features and improvements of the previous firmware are also included in this version.
Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
can anyone help me get this oppo firmware upgrade?
joedog2026 wrote: »can anyone help me get this oppo firmware upgrade?
Go to OPPO's site.Political Correctness'.........defined
President of Club Polk -
https://www.oppodigital.com/support/blu-ray-bdp-103/blu-ray-BDP-10x-Firmware.aspx
Let me warn you that if you have NEVER done any firmware updates you need to check which firmware you have THEN get the next firmware from the current firmware on the player. If you try to just jump to the most current you have a good chance of bricking your player.
DO NOT INTERRUPT THE FIRMWARE INSTALL.
IT'S best to download to a thumb drive first. An interruption can also brick the player.
Follow Oppo instructions to the letter. -
I haven’t seen or done a firmware update in years. I thought these players are well past that point.
Correct, there's nothing new. These are all old updates from several years ago. If you have never done any of the updates, can't hurt to get the old updates they offered. -
This is the page for the last firmware update in 2017: https://www.oppodigital.com/support/blu-ray-bdp-103/BDP103-firmware-83-1226.aspx
I've always just done automatic updates over WiFi but the USB update is a good option.
Start by checking what firmware is on the player already. No need to do an update at all if the player is working correctly.
