Anyone has a schematic or service manual for any DSW-Micropro subs?
You're welcome, good luck with your repair!
Hi @SeleniumFalcon, I have a DSW Pro 660wi with a blown amp, and was wondering if you have the schematic for that as well?
I've temporarily rewired it to work passively, but would like to replace the broken components if possible.
Thank you!
Schematic sent...
Plis SeleniumFalcon, send me a copy of the schematics for the DSW-2000 Thanks in advance!
Schematic sent...
SeleniumFalcon wrote: »Schematic sent...
No power on a dsw1000 - can I get whatever schematics you may have access to for this model?
Mine is one of the power thermistors - I don't think they're the same based on the remnant of the second-line of print, as it's illegible as it is, but TH1 has a hole blown in it. DB4 next to it has a SCK 048.Post edited by Masejoer on -
Schematics sent..
Hi SeleniumFalcon, could you please send me a copy of the schematics for the DSW-3000? Thanks in advance!
Schematic sent..
Any chance I can get the schematic @SeleniumFalcon
To clarify I have a DSW4000 @SeleniumFalcon
I've sent the available schematics...
Can you resend I may have deleted email by mistake
It was bounced back as "undeliverable", I'll re-send it.
It failed again, maybe you could PM me with another email address?
SeleniumFalcon, can I get a copy of the chematic for the DSW1000? Thanks a bunch!
Schematic sent...
@SeleniumFalcon hey! I have a dsw2000 and am looking for the schematic if you don’t mind sending it over please and thank you!
Schematic sent...
Hi @SeleniumFalcon, long time lurking here and reading posts.... I do have 2 DSW MicroPro 3000 with no power. Would you be so kind to send me a copy of the schematics...thanks a lot...
Schematic sent...
thank you very much...
You're welcome, good luck with the repair!
Hello @SeleniumFalcon, I am yet another person with a DSW1000 with a non-functioning amp board, could you please forward the schematics? I have power through the rectifier but something amiss after that. Thank you!
Hello, schematic sent, good luck with the repair!
