Is Armaflex still available?
ratpin
I see a lot of people recommending this product to help seal up the cabinets. I just finished installing hurricane nuts while I wait for my crossovers. Can someone provide a link to the correct type and thickness if it’s still available? Thanks.
Polk: / SDA-CRS / SDA-1C / M-10B / M-7B / M-5 / M-5jr / RTA-11T / LSIM703 / LSIM704 / LSIM706 / RTI8 / CSI3 / CSI5 / RTI4 / RTI-A5 / CSI-A6 / RC80i / RC85i / RC6s / PSW300 / Atrium6 / Atrium4 / About a dozen pair of Atrium45 lol.
Home depot has it. Yes it is available. It's a plumbing pipe wrap.
https://www.homedepot.com/p/Armacell-2-in-x-30-ft-R-1-Foam-Insulation-Tape-TAP18230/100539553
Adhesive side to the driver NOT the cabinet. Overlap a bit and cut on the diagonal to avoid air leaks.
I use an old soldering iron to burn screw/bolt hole to avoid it twisting under the flange. -
Perfect! That’s what i was looking at.
Thanks doggPolk: / SDA-CRS / SDA-1C / M-10B / M-7B / M-5 / M-5jr / RTA-11T / LSIM703 / LSIM704 / LSIM706 / RTI8 / CSI3 / CSI5 / RTI4 / RTI-A5 / CSI-A6 / RC80i / RC85i / RC6s / PSW300 / Atrium6 / Atrium4 / About a dozen pair of Atrium45 lol. -
Is this still worth the effort if all my original gaskets are good?Polk: / SDA-CRS / SDA-1C / M-10B / M-7B / M-5 / M-5jr / RTA-11T / LSIM703 / LSIM704 / LSIM706 / RTI8 / CSI3 / CSI5 / RTI4 / RTI-A5 / CSI-A6 / RC80i / RC85i / RC6s / PSW300 / Atrium6 / Atrium4 / About a dozen pair of Atrium45 lol.
No, use the old gaskets.. -
NO!!!!!!!!!Political Correctness'.........defined
