XS Amp Case...Part 2
xschop
Have some time to start a 2nd amp case for my nearfield/desktop rig.
I'll be inserting an Aiyima A04 this time with integrated dial mechanism. It will only be 3.5" tall and same 7.5" diameter as Ill machine the TPA3251 board to insert sideways. I fly-cut the baseplate this time as well...
These amps don't even need fans, so only adding a center and 3 lateral air ports for convection flow...
Post edited by xschop on
Not sure I posted this pic. Still running this amp on my desktop setup. Starting to pre-game a Starkrimson module build with one of these cases, instead with heatsinks towards the top and SWPS/IEC at the bottom...
Don't take experimental gene therapies from known eugenicists. -
Jeezus. That setup is so cool.The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
Thanks Steven, getting some screen time as I reply. I have the AM5 sub still running in parallel also. Doesn't have the all-out kick as the RM1000, but digs a little lower here. Looking forward to your next desktop project as well...
What’s the guts look like?
I machined it for the A04 case to drop right in without it's top cover (since these cheap factory black cases trap the heat) and thermal paste applied to the base plate for maximum heat dissipation. I also drilled the same diameter hole thru the factory bottom case where it interfaces the billet bottom plate for convection around the 3251 chip/PCB... It barely gets warm after hours of cranking the large dia. knob.
Love it- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Cleaning up and extending wiring....
Well, at least I found the gain issue. Was a setting in Linux Mint's Pulse Audio. The Cambridge DAC 100 was recognized and has it's own output setting.
This amp is a beast for it's footprint.
I am on the fence weather to get a Fosi ZD3 or SMSL D6-S, if anyone has opinion.
Set it up on the bedroom rig. B&O C30s in parallel with RM1000 sub. Overkill but will be ripping CDs all day to FLAC.files.
New mini PC is way faster than HP mini PC....
That thing looks so nice with the ribs.
[amazed]The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage -
Thanks Steven. It more than doubled the heat dissipation in that area.
Pug Commander, better be baby backs or I cry foul.
Updated the first 3E amp build for the owner.
Took me only 10 minutes to disassemble and chuck up on the lathe. He likes his ribs elevated lol.
The round chassis reminds me of Thor audio
Pretty cool. Is that a record player?Don't take experimental gene therapies from known eugenicists.
Tube preamp with separate power supply. The tubes are in the hollow out center section.
Couldnt make out what it was on the phone.
Whats diameter of it?
Im going to try and source a 9" diameter tube soon for another dreadnaught case and make it shorter.
