Difference between SL5500 and SL5505 tweeters?
Raimund
Raimund Posts: 6
edited March 18 in Speakers
Hi there,
one of the tweeters in my trusty RT400 speakers is broken. The RT400s have SL5500 tweeters built in. I am located in Europe and buying a replacement in the US isn't worth it for me, since with shipping and tariffs I could buy a whole new RT400 for the same money. However, here in Europe I can only find SL5505's.
My question is: Is there any difference between the models SL5500 and 5505 (I also found 5501 somewhere) and are all of them compatible with the RT400 speakers?
Thanks for your help!
Btw. I did already ask Polk's Customer Service, but they couldn't help me as they don't have the RT400 documentation anymore.
Best Answers
    VR3 Posts: 29,751
    Answer ✓
    They are the same but one can't go next to certain televisions
  • Unknown
    edited March 19 Answer ✓
Answers
    xschop Posts: 5,838
    Did they try to sell you a soundbar.
  • Unknown
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,386
    Let me see what I can find out.
    VR3 Posts: 29,751
    If I had to guess. It's probsbly a bucking magnet versus not
    Viking64 Posts: 7,814
    VR3 wrote: »
    a bucking magnet
    LANGUAGE!!!!!! :o
  • SeleniumFalcon
    From Polk's transducer engineer:
    "The SL5500 tweeter is soft shielded, but I'm not sure about the SL5505." "Soft shielding" means it has a reverse polarity magnet attached but not a shielding cup.
  • Raimund
    Raimund Posts: 6
    edited March 19
    thanks for all the answers so far!
    so are they different enough that it wouldn't be a good idea to combine them? (meaning an SL5500 in one speaker and a 5505 in the other)
    but would it be possible to use the 5505 in an RT400 speaker at all? (i could probably get a pair of 5505s and change both tweeters)
  • Raimund
    Raimund Posts: 6
    ok, that's great! since I have no TV and only use the RT400s for cd- and vinyl-listening, i'll get the SL5505!!
    thanks, everybody!
    xschop Posts: 5,838
    I'D opt for SL5000's if you can find them in your area.
    Very smooth with Polk's Dynamic Balance material/dome.
    Just another option.
  • Raimund
    Raimund Posts: 6
    Toolfan66 wrote: »
    I would stick with matching the tweeters, no matter what option you pick to use..
    That's what I would prefer as well, as I guess the difference in running time alone (25 years vs. zero - the replacement is unused) would make a difference in sound, right?
  • Raimund
    Raimund Posts: 6
    xschop wrote: »
    These are indeed available from the same dealer, if a bit more expensive. However, if they are a significant upgrade, I would definitely consider getting those. Would I have to change anything in the crossover or could I just install them as is?
    VR3 Posts: 29,751
    Only time tweeters degrade over time would be if they used ferrofluid
    xschop Posts: 5,838
    edited March 20
    Forgot what the DCR is of the 5000's, but if it is within +- 0.5 ohm. of factory tweeters Id use them. They are smoothest of the bunch.
    Guess I should add the 5000s are better suited for critical music listening. All RT speakers were geared for home theater and had bright sounding tweeters
  • Raimund
    Raimund Posts: 6
    Both the 5000's and the 5500's seem to be rated at 6 Ohms, however that is only from a few ebay auctions where people posted photos of multimeter measurements. The range was actually about 5.5-6.8 Ohms - both tweeters measuring in the low and high end of the spectrum.
    xschop Posts: 5,838
    Well, when some folks use a voltmeter, some don't account for or zero the meter leads.
