XS Amp Case...Part 2
xschop
xschop Posts: 5,379
edited August 2024 in DIY, Mods & Tweaks
Have some time to start a 2nd amp case for my nearfield/desktop rig.
I'll be inserting an Aiyima A04 this time with integrated dial mechanism. It will only be 3.5" tall and same 7.5" diameter as Ill machine the TPA3251 board to insert sideways. I fly-cut the baseplate this time as well...
These amps don't even need fans, so only adding a center and 3 lateral air ports for convection flow...
Post edited by xschop on
    xschop Posts: 5,379
    edited December 2025
    Not sure I posted this pic. Still running this amp on my desktop setup. Starting to pre-game a Starkrimson module build with one of these cases, instead with heatsinks towards the top and SWPS/IEC at the bottom...
  • Jeezus. That setup is so cool.
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
    xschop Posts: 5,379
    Thanks Steven, getting some screen time as I reply. I have the AM5 sub still running in parallel also. Doesn't have the all-out kick as the RM1000, but digs a little lower here. Looking forward to your next desktop project as well...
  • ALL212
    ALL212 Posts: 1,664
    What’s the guts look like?
    Aaron
    Enabler Extraordinaire
    xschop Posts: 5,379
    ALL212 wrote: »
    I machined it for the A04 case to drop right in without it's top cover (since these cheap factory black cases trap the heat) and thermal paste applied to the base plate for maximum heat dissipation. I also drilled the same diameter hole thru the factory bottom case where it interfaces the billet bottom plate for convection around the 3251 chip/PCB... It barely gets warm after hours of cranking the large dia. knob.
    VR3 Posts: 29,540
    Love it
    xschop Posts: 5,379
    Cleaning up and extending wiring....
    xschop Posts: 5,379
    xschop Posts: 5,379
    xschop Posts: 5,379
    xschop Posts: 5,379
    Well, at least I found the gain issue. Was a setting in Linux Mint's Pulse Audio. The Cambridge DAC 100 was recognized and has it's own output setting.
    This amp is a beast for it's footprint.
    I am on the fence weather to get a Fosi ZD3 or SMSL D6-S, if anyone has opinion.
    xschop Posts: 5,379
    edited January 24
    Set it up on the bedroom rig. B&O C30s in parallel with RM1000 sub. Overkill but will be ripping CDs all day to FLAC.files.
    New mini PC is way faster than HP mini PC....
  • That thing looks so nice with the ribs.
    [amazed]
    Viking64 Posts: 7,618
    [amazed]
    xschop Posts: 5,379
    Thanks Steven. It more than doubled the heat dissipation in that area.
    Pug Commander, better be baby backs or I cry foul. :D
    xschop Posts: 5,379
    Updated the first 3E amp build for the owner.
    Took me only 10 minutes to disassemble and chuck up on the lathe. He likes his ribs elevated lol.
  • invalid
    invalid Posts: 1,521
    edited March 21
    xschop Posts: 5,379
    Pretty cool. Is that a record player?
  • invalid
    Tube preamp with separate power supply. The tubes are in the hollow out center section.
    xschop Posts: 5,379
    Couldnt make out what it was on the phone.
    Whats diameter of it?
    Im going to try and source a 9" diameter tube soon for another dreadnaught case and make it shorter.
