SDA CRS+
Grabber70Mach
Grabber70Mach Posts: 51
edited March 17 in Vintage Speakers
What is the average price for a set of SDA CRS+ with factory stands and cable. Appear to be in 7-8 condition, original owner, has a dent across the woofer in the back on one speaker. Has anyone had dealings with Audiogon?
    F1nut Posts: 52,009
    edited March 17
    Look like the original CRS due to the blade/blade SDA cable socket. The rear grill is easy to remove and push out the crease. Price is reasonable.
    I've bought and sold on Audiogon over the years, never a problem.
    F1nut Posts: 52,009
    I had to refresh my memory. There was a CRS+ with the blade/blade SDA cable circa 1986. It has two separate crossover boards. The SDA driver utilizes two 130uF caps!
    They cannot be used with non-common
    ground amps or mono blocks.
  • Does this make then less desirable than other versions?
    F1nut Posts: 52,009
    Definitely
    xschop Posts: 5,417
    Is it a single tweet model?
  • I'm not sure he doesn't show any pictures with the front grills off. You have to have a credit card on file to ask any questions. I'm not too keen on that.
    Toolfan66 Posts: 18,189
    And why I skip over Audiogon..
    xschop Posts: 5,417
    10 years ago, shipping wouldn't have been a deal killer. Today....It's dead in the water.
