SDA CRS+
Grabber70Mach
What is the average price for a set of SDA CRS+ with factory stands and cable. Appear to be in 7-8 condition, original owner, has a dent across the woofer in the back on one speaker. Has anyone had dealings with Audiogon?
Look like the original CRS due to the blade/blade SDA cable socket. The rear grill is easy to remove and push out the crease. Price is reasonable.
I've bought and sold on Audiogon over the years, never a problem.Political Correctness'.........defined
President of Club Polk -
I had to refresh my memory. There was a CRS+ with the blade/blade SDA cable circa 1986. It has two separate crossover boards. The SDA driver utilizes two 130uF caps!
They cannot be used with non-common
ground amps or mono blocks.Political Correctness'.........defined
Does this make then less desirable than other versions?
DefinitelyPolitical Correctness'.........defined
Is it a single tweet model?Don't take experimental gene therapies from known eugenicists.
I'm not sure he doesn't show any pictures with the front grills off. You have to have a credit card on file to ask any questions. I'm not too keen on that.
Grabber70Mach wrote: »I'm not sure he doesn't show any pictures with the front grills off. You have to have a credit card on file to ask any questions. I'm not too keen on that.
And why I skip over Audiogon.. -
10 years ago, shipping wouldn't have been a deal killer. Today....It's dead in the water.Don't take experimental gene therapies from known eugenicists.
