5JR crossover upgrades and questions
    xschop Posts: 5,417
    I'll be getting back a set of 5Jr's I built way back with the tweeter directly above MW, but closer than factory. I'll have a listen, since the bezel there is recessed a touch deeper with a curved profile. It also will glue in so there are no extra fasteners on the edge and the planes are machined perfectly flat when mated.
    I will be getting back the 5Jr crossovers and the 5B crossovers that he was running in them. The 5B X-overs seemed smoother or not as out front as the 5Jr's in them from what I remember.
    xschop Posts: 5,417
    Hadve these on the bench tonight installing binding posts and forgot that the phase of the tweeter is reversed on these...
