what's the difference?
Is there any difference between the "subwoofer" cables vs. a regular RCA type cable vs. a digital coax cable? I think digital coax is a solid core cable right? Is the subwoofer cables solid core or are that strands?
TIA
TIA
System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
Post edited by 2+2 on
Since you mostly need shielding for a subwoofer cable, I would imagine a video cable would be the best subwoofer cable you can buy - no? I mean...it IS shielded the most, right?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
so the subwoofer cable is the same as a RCA interconnect huh! Thanks Sean for the clarification.....I was looking to buy one but they are all like 12 feet long.....I need a 3 ft run....I'll just use an RCE interconnect....thanks!System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
bandwidth capabilities would be the only thing I would say that would technically be different. For a sub cable, you really want very little bandwidth. I know RG59 works nice where RG6 does not sound anywhere close.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
what type of wire are RG59 and RG6? I assume they are some type of solid wire....System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
standard coax cable... like for your cable/sat wiring.Never kick a fresh **** on a hot day.
gotcha...thxSystem 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
