Rig finally up and running
    heiney9 Posts: 25,710
    Geoff4rfc wrote: »
    heiney9 wrote: »
    Geoff4rfc wrote: »
    heiney9 wrote: »
    Is that a wet bar? Or dry?
    Dry.
    Right on, sounds like you're leaning towards tearing that out then? Opening up your space? No headache of removing water lines.....
    Correct no plumbing to deal with. I am leaning that way, but there is also the "my dad designed and built that and he's no longer here" thought too. Things like that pull at the heart strings a bit.
    If it were slid 3-4' farther back. There would be plenty of room for a listening chair. Right now I'm right up against the center bump out in the bar with the back of the loveseat. There is an over stuffed leather chair and ottoman that I could switch out for a listening chair. Takes up less space, but I'd still have to be as far back.
  • Geoff4rfc
    Geoff4rfc Posts: 3,053
    heiney9 wrote: »
    Geoff4rfc wrote: »
    heiney9 wrote: »
    Geoff4rfc wrote: »
    heiney9 wrote: »
    Dry.
    That's a heavy dilemma for sure. I believe in time you will find a solution that will accommodate both the need for function and the satisfaction of sentiment. My guess is you're already trying to figure out how to just move it.
    Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
    VR3 Posts: 29,751
    How large is this space overall in volume
    billbillw Posts: 8,287
    Another question: How does the room upstairs with your ES20 rig compare? Is there a reason you want the L600 in the basement?
  • Milito
    Milito Posts: 2,003
    You'll get there it just takes time when you move into a new place as we all know.
    VR3 wrote: »
    Approx 14' W x 30'L x 8' H
    VR3 Posts: 29,751
    So most 3 way speakers the woofers play up to around 300hz.
    .dual 7s are essentially a10 inch woofer.
    Playing such a wide range, there is a sacrifice to extension and volume as you would otherwise be to loud in a critical point for some instruments and vocals.
    The room is adding nothing where as a crawl space definitely adds room gain.
    I just think you are expecting to much from the speakers for that size room on a slab
    My room is not to different and I am running the surface area equivalent of 14 x 7 inch drivers and there are moments I would concede I need a subwoofer and I also experience tremendous room gain.
  • pearsall001
    pearsall001 Posts: 5,399
    I know you don't want to hear this...but...you're gonna need a sub or better yet dual subs. The room is just too much to handle for the speakers to live up to your expectations.
    My room is almost identical at 13x30x7 on a cement slab & I've lived here since 1992 so I'm quite familiar how the room effects the sound.
    I've had many speakers both stand mounts & towers over the years & without the subs the sound was not up to snuff, now don't get me wrong I always had very good sound but lacking. Enter the subs & wallah!! There it was. I know you're not a sub guy but just food for though here. Just take your time & have fun experimenting.
  • dromunds
    dromunds Posts: 10,174
    I’d remove the bar.
  • Geoff4rfc
    Just an idea......and of course space A......ever hangout in the garage.....tinkering and dinking around, friends come over, a few beers here and there. Mission, should you choose to accept....Relocation of dads bar, transforming garage into place of relaxation and memories and of dedication.
    edited March 2025
    Thanks for all the feedback. I will take it all into consideration. Setting up the best sounding rig is going to take time and some experimentation.
    Keep the discussion going.....this rig has to stay in this room or the office/bedroom down here. No options for main level or garage. I live in the Midwest, 20 miles from the Wisc/IL border, Winter can be harsh. Turing the garage into a man cave isn't really an option. Both because of the build out and loss of a 2 1/2 car garage and partly climate related.
    These days how does one incorporate a sub into a 2ch system? Obviously my 2ch gear has no options for sub management.
  • invalid
    invalid Posts: 1,559
    Setup your system in the office room and find out if it works out better before moving the cool looking bar your dad built. It may or may not sound better in the office, but there is only one way to find out
  • pearsall001
    Hey Brock I just sent you a PM.
  • polrbehr
    polrbehr Posts: 2,875
    dromunds wrote: »
    I’d remove the bar.
    Or, at the very least, move it if you can.
    I totally get the sentimental aspect of it, but two things I would think about - one, if you bought the house from someone you didn't know at all, would it already be gone? And two, if your dad was still here, do you think he would shrug and say "it's your house now, you have to live there" .
    Just my $.01 (don't have .02 these days LOL)
  • gp4jesus
    gp4jesus Posts: 2,021
    edited March 2025
    bcwsrt wrote: »
    I'm super-interested in your comments about the power conditioner once you get a feel for it. I've had one of those on my wishlist for a while.
    An APC H15* is what I currently have.
    Ditto*
    Also curious to learn Brock’s comments
    *all connected w/Premiere ICs
  • Gardenstater
    Gardenstater Posts: 4,945
    Try the free acoustic analysis at soundproof.com and see what they say:
    https://www.soundproofcow.com/acoustic-analysis/
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    I did some tweaking. The speakers were 22.5" off the back wall. I moved them closer and are now 18". Dialed in the equilateral triangle listening position more precisely. Took the rubber off the feet so they are now on spikes and leveled. Also adjusted the toe-in a bit.
    Made a pretty big difference. The bass is back and at low to mid levels it sounds fantastic. Get it passed a certain point (which is fairly loud) and too many reflections start to make things sound unbalanced and just a bit strident at times. I desperately need some room treatments.
    Now down that rabbit hole of how/where to install room treatments.
    edited April 2025
    I've made a decision to make some minor changes in the rig. I will continue to stream Qobuz as it has been fantastic. I just modded my BlueSound Node 3 with the board to run an external linear PS. Great piece of gear that works and sounds great.
    One small issue with Qobuz is has some artists whose entire catalog isn't available and artists not available at all.
    Since replacing the Squeeze Box Touch I no longer have the ability to run a music server of my own music. I decided to purchase a Roon Nucleus One which is a music server and will allow streaming over the network (wired and wireless).
    As is my belief that switching walwarts are a compromise I also purchased a 19V 4A linear power supply to run the Roon NO. With Roon you also have to run their software/architecture and Qobuz can be integrated into the architecture. Roon is a subscription service. I also bought a dedicated 9" Lenovo tablet to control everything.
    Here are some preliminary photo's. Hope to have it up and running by the end of the weekend.
    Also pictured Samsung 4TB SSD for storage and the Lenovo tablet
    SCompRacer Posts: 9,399
    edited April 2025
    heiney9 wrote: »
    If you can't get it right with the sub controls, you have to look into some form of EQ for them. Use either free room software or purchase something like Dayton OmniMic and do room sweeps to adjust. I did sweeps to get optimum speaker placement first. Steady tones can overload a room played too long so a sweep tone works best. Then I tried subs positioned all over the room to find they worked best against the wall by speakers. This all took me a few Saturdays.
    The room, the room.... I had to add subs due to a large open main level with 14' ceilings. Otherwise no deep boom boom with dubstep or pipe organ. :D Only one speaker is near a corner, and I have stacked bass traps there, singles in other corner and by chimney box. Even after subs added and dialed in, if I leave the sweet spot and walk towards center of room, the bass starts to disappear. Keep walking it reappears. I was lucky and able to just use sub controls to dial them in.
    The subs did have some extra handy adjustments. A boundary switch, which brings in a –3-dB for corner placement and a +3-dB bass boost away from corners. They only come in when needed.
    edited February 14
    It's been almost a year since I started getting the main rig set. Here are some current photos. Haven't gotten as far as I wanted with the room, but the room is serving it's dual purpose for the time being. Entertainment space doubling as a 2ch listening room. I put cellular (cloth blinds in the window for sound treatment). I put a fairly thick rug down between my listening chair and the front speakers.
    Still a bit crammed with too much furniture. All the big pieces are on sliders and we can move them around as necessary when entertaining or when I put my singular listening chair in it's perfect spot (see the back of the maroon chair). It's like ultra suede material and the cat likes to sit in it when I'm not using, hence the gray sheet over it.
    I haven't been listening as much since I don't really have it dialed in yet and after about 30 minutes (after warm up) I don't like what I'm hearing and I walk away. Shrill, strident out of balance top to bottom. I've been avoiding it because I'm at a crossroads.
    What worked at the old house as far as tube choices isn't getting it done. I've been rolling many combos over the past couple weeks and while I can fix a few aspects other aspects suffer. The problem is the infinite amount of tube combo's for the Avant. It responds very well to rolling which is sharp double edged sword.
    If you look at the above photo you see a black box on top of the Avant pre-amp. I bought a couple of Pass DIY Pre's. This one is a superbly put together Pre/headpone amp called the ACP+ (Amp Camp Preamp +) these typically run with a 24V switching Meanwell supply and no case. The builder of this one put in a linear power section with a torrid and a nice heavy case. I had been using it in the office rig and it sounded phenomenal.
    From Nelson: asked me to design a preamp that would also serve to drive headphones. The gain stage for each channel resembles a miniature version of the First Watt J2 amplifier, with an input circuit using a differential pair of P channel Jfets Q1 and Q2 biased by a constant current source Jfet Q3, and driving a Common Source Mosfet Q6 which in turn is biased by Mu-Follower Q5. Q5 is controlled by opto-isolator Q4, which sets a DC voltage based on the sum of the currents through Q5 and Q6, keeping that sum constant.
    Consistent with the topology based on the J2, I selected parts and values so as to somewhat replicate the sonic signature, including a distortion characteristic with the signature negative phase second harmonic character.
    Two of these gain stages are arranged on a single pc board with power supply filtering, input and output connectors, input switch and volume control
    I decided to hook this up in the main rig since I am not getting what I want from the Avant at this moment. When DIY Audio sells a kit version of any NP design, Nelson is always generous enough to supply the JFets, Mosfets, any FET's etc. They are always from his personal stash and matched, etc. The guy has (2) warehouses full of "bulk" parts.
    I have always been a believer in simple circuits are always preferred w/high quality parts. This DIY pre sounds excellent. Far better than it should vs. cost to build. But NP stuff always sounds great. I have no doubt this could compete with many $1K pre-amps. It has its limits. It's falls short in ultimate transparency, the sound stage is just a bit closed and the lower bass can be just a tiny bit loose. But I'm really nit picking. If it only was remote, I could live with this for awhile as a place holder.
    I am about ready to move the Avant along. I'm not sure I want to give up tubes entirely, but the rolling combos and my amount of tubes has gotten me into an endless loop of swapping tubes and still not finding that particular presentation I am listening for. I want to come downstairs, warm up the rig and listen to music. That's not happening since I am not entirely happy with the sound so I'm futzing with infinite tube combos.
    I think my next step is to try some room treatments. I think it would be assbackwards to get the gear and then treat the room. I've taken a couple steps with the blinds and rug. Looking at the room maybe give me some input for a starting point. There are not alot of soft surfaces and room echoes quit a bit. At normal listening levels it's fine, but if I goose the volume certain frequencies ramp up and the audio picture starts to fall apart.
  • bcwsrt
    bcwsrt Posts: 2,691
    That looks like a super-cool space! But ... it appears you’re a little limited with what you can do as far as room treatments with the built-ins on both sides, the doorway, the bar and soffit above.
    GIK Acoustics offers free, no obligation room advice. It would be interesting to see what they say. They recommended at least 2X what I actually ended up going with in my room, but their advice helped narrow down a good starting point for my room.
    Brian
