Old Polk monitor 10 vs New Polk RTI A1
Hey there,
I currently have the Polk RTI A3 and I'm pretty happy with them but I want to get bigger sound. I listen mostly for 90s House on vinyls electronic music, jazz and rock.
I saw a pair of monitor 10 in good condition for sale and I wondered if I get better sound from them compared to my RTI A1, I don't want to lose clarity but I do want more bass and big open sound. Do you guys think Ill enjoy the monitor 10 more than the RTI A3?
  • adiryakobi
    BTW I have a 25 sqm room and 150v pioneer receiver for now
  • lawdogg
    lawdogg Posts: 472
    Yes, I think it's a good idea to at least try the Monitor 10s (regardless of which generation / configuration they are).
    I personally would assume you'd like the Monitor 10 far more than yours (whether you have RTI A1s or A3s - unclear from your post)... especially if you're looking for big bass and big open sound.
    The world is your oyster in terms of modifications if you get the Monitor 10s and like the big bass & open sound, and then want to enhance them for better treble, balance, clarity, etc...
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
    F1nut Posts: 52,406
    Stick with vinyl as the plural for records; it's more accurate and respected within the community. If you need to emphasize multiple items, use the word "records" instead.
  • adiryakobi
    any more opinions?
    Viking64 Posts: 7,836
    adiryakobi wrote: »
    any more opinions?
    I have plenty but I'm sure you don't want them.
    F1nut Posts: 52,406
    edited January 28
    Yes
    FYI, your receiver power would be rated in watts, not volts.
