Amplifier options to power Polk SDA CRS under $500
Recently picked up a pair of Polk SDA CRS. Order the interconnect cable off of ebay and am running them on an old Realistic integrated amp that is underpowered. I would like to replace the amp with something appropriately powered for less than $500. They are set up in a 14'x12' room. I dont need to max them out but want something better matched to power them. Any help would be greatly appreciated!
Answers
    Tony M Posts: 11,991
    edited January 22
    Look at your local Facebook Marketplace. If you see some, post them here, and we'll tell you if it MIGHT work.
    Used receivers do have risks, though. They might be great or garbage, but they should be cheap and affordable. Way below 500.00 for sure.
    Check online for new ones, and look at the reviews of amps or whatever might have 100 wpc or more.
    gudnoyez Posts: 8,213
    edited January 23
    I power a pair of CRS+ with a Adcom 545II that was in mint condition that I found on Craigslist for $200 does a good job look on E-Bay they still come up for sale once in a while you would need a preamp. Welcome to the Forum.
