Review: Benchmark AHB2 Amp
Well not really. Just a few pictures comparing the size difference between the A21+ an 80 lb. back breaking monster & the AHB2 a 12.5 lb. easy on the back contender.
A little too early to report on the comparison between the two. Stay tuned.0njbgbfdd0u8.jpg
«134
    pitdogg2 Posts: 27,364
    In with 27.....
    billbillw Posts: 7,824
    edited December 2025
    It's so cute 🤣
    Like a wittle baby.
  • pearsall001
    pearsall001 Posts: 5,328
    It definitely is "wittle" but let that fool you.
  • jdjohn
    jdjohn Posts: 3,385
    It definitely is "wittle" but don't let that fool you.
    Fixed it for ya :) I see cables hooked up to the little guy, which means some listening is occurring. I have posted thoughts about my experience with the AHB2, so curious to read your findings. With your tube pre, there could be some real magic when combined with the AHB2. I'm sure you'll experiment with the input sensitivity setting options on the rear.
  • pearsall001
    jdjohn wrote: »
    Well I'll be brief here just to get some quick thoughts out about the A21+ & AHB2 comparison.
    I'm almost ready to head on up to the attic & bring down one very large box for shipping purposes.
    More listening time is needed to finalize my decision. More to come.
  • bcwsrt
    bcwsrt Posts: 2,525
    Not a “wittle” box, eh? 🤔😜
    Brian
  • pearsall001
    bcwsrt wrote: »
    There ain't nothin "wittle" about this box!! 😳 Man oh man this has really been an eye opener or should I say ear opener!
    heiney9 Posts: 25,529
    jdjohn wrote: »
    In all my experiences in this hobby, you haven't given it enough time. I mean the damn thing isn't even broken in yet. The initial honeymoon is almost always positive because many times the new piece is "different" than the old piece of gear.
    Even staying with Pass it took me months to be sure the XA25 was a keeper over the Aleph 30. They are completely different animals, but I had to be sure which one I preferred for the long run.
    You can tell me that it was love at first listen, but boy, oh boy I can't tell you how many pieces of gear, cables and tubes I spoke too early about their virtues only to decide they weren't all that after proper evaluation.
    Evaluation is a long term proposition. I take many months and many take weeks. But a couple of days.....I don't believe it.
    Clipdat Posts: 13,100
    audioluvr Posts: 5,990
    Box up the A21 and put it in the closet. Two days before you need to return A2HB, hook up the poor ol A21 and audition it with someone young with good ears.
    bcwsrt wrote: »
    I bet! Pretty interesting sensation when the S/N ratio of your amp meets/exceeds your source. Suddenly you can literally hear so much more.
    I will never sell my LA4 (or my HPA4) or my AHB2, great pre and amp!
  • pearsall001
    heiney9 wrote: »
    jdjohn wrote: »
    I hear ya Brock but the difference is like night & day. I wasn't expecting anything like this at all. This damn thing simply opens up all windows into the music.
    I'm not ready to throw the towel into the ring just yet but it ain't looking too good for A21+.
  • pearsall001
    Clipdat wrote: »
    bcwsrt wrote: »
    Bingo!!! This thing is so quiet its uncanny. It's S/N ratio is like 132 from the first watt to the max, it doesn't waver. I never really got too caught up in specs but this is definitely let me hear so much more (as you mentioned).
    Not done listening yet but unless things change I just don't see it going back.
    I called Benchmark today to discuss what I was hearing & they politely laughed & said yep... they hear that alot from new customers. He said when your ready to even bring everything up a few more notches to consider one of their pre's. It just keeps getting better & better they said.
    I think the low gain is probably the biggest difference you are hearing. You're getting more effect from the preamp which is probably a very good thing. Honestly nobody, not even the best golden ears, can hear the actual difference between a SNR of anything beyond 110dB. Most in our later years probably can't discern beyond 95dB. It is nice to see an amp designer using lower gain. Let us use our preamps beyond ~30% on the dial!
    billbillw wrote: »
    Yes, that's true as the AHB2 imparts no real sonic character of it's own, so you'll be able to more clearly hear the attributes of your upstream components (and cables).
    I experimented with several types of XLRs between my LA4 and AHB2 back when I first got them. It was plain as day to hear the differences of the XLRs in this position. I think I tried at least 5 different types and then settled on what I preferred.
    With neither the LA4 or AHB2 having any real sonic coloring of their own, the XLRs running between them made a much more impactful difference than you might expect.
  • jdjohn
    jdjohn Posts: 3,385
    At one point, I had a Benchmark stack of a DAC3/HGC, feeding into an HPA4 preamp, and then into an AHB2 power amp. Eventually, I took the AHB2 out of the chain. The only real reason was that I wanted to experiment with other power amp topologies.
    It all depends on listener preferences. I often consider replacing my HPA4 preamp, but man, it is so transparent, and has so many adjustment options...I can't ever justify taking it out of the chain. I personally love the transparency offered in the HPA4...which has the headphone output.
  • pearsall001
    I think I know what's happening here with my listening experience. As we all noise is a big culprit that affects everything in the audio chain & that certainly pretains to the amp.
    With the AHB2 in the chain & due to it's topology & vanishing low noise it simply lets the other gear strutt there stuff without adding any more noise into the signal.
    An easy way to explain what I'm hearing is simply more of what's already there on the recording. Without a doubt the sound is more robust & engaging. Like a fine piece of art on a canvas but now transferred to a much larger canvas. Same art just more of it. Just the way I'm hearing things.
  • maxward
    maxward Posts: 1,718
    I never heard a Benchmark amp, but the guy who sold me my 50-pound Eastern Electric M520 integrated had it replaced by the Benchmark pre and power amp. At the time, I thought they were “cute”. In reading Drew’s past reviews and posts here, I’ve grown to trust his opinions.
  • SIHAB
    SIHAB Posts: 5,607
    These are the speakers involved?
    "Two Channel:Magnepan LRS"
  • pearsall001
    Clipdat wrote: »
    Did you try any of Benchmarks cables? What XLR cables did you go with.
    I haven't tried Benchmark's XLRs but I have tried their Canare Star Quad speaker cables and they sound excellent, imo.
    I ended up using the Audioquest Yukon XLRs as I enjoyed their sound signature the most, perhaps due to the silver content.
  • pearsall001
    Clipdat wrote: »
    Thanks for the info Drew.
    I tried sending you a PM but it wouldn't go thru.
  • pearsall001
    Well it's been a week now & things just keep getting better & better. The AHB2 is something to be reckoned with. Might be time to get out the packing tape & that big box up in the attic.
  • pearsall001
    I'm finding it amazing how the absence of noise in the system can really open things up to a sonic level that you didn't know existed. You're so used to noise without even knowing it until it's not there.
    Bingo
    Sorry, but I think you have drunk the coolaid. There may be many reasons that you prefer the sound from this amp, but it's not the S/N ratio.
    The Parasound is not a noisy amp by any means
    billbillw wrote: »
    You’re absolutely going to be able to hear the difference between a 88.7db (A21+ a-weighted at 1w, per Stereophile) and a 108db (AHB2 s/n ratio, also a-weighted per Stereophile)
    So yes by those directly comparative “means”, the A21+ is a noisy amp.
    That being said I don’t even know why I’m posting this. It’s not going to change anyone’s stance. Taking the AHB2 challenge and hearing the difference for yourself is the only way to understand.
    treitz3 Posts: 20,132
    Where have I heard that before?
  • pearsall001
    billbillw wrote: »
    Definitely some Jameson Reserve Series Black Barrel or locally brewed IPA but no Kool-Aid here.
    And yes the A21+ is a noisy amp compared to the AHB2. It's a tough nut to swallow but it is what it is.
    Now I've never got hung up on measurements but this is a case of hearing is believing.
    I've had the A21+ for a few years now & I'm very familiar with it's sound signature & was very, very pleased with it's performance.
    Now enter the AHB2 & my listening experience with it in my system with my upstream components, speakers & room interaction was a ear opener!
    My non-reviewer take on this is that the AHB2 simply let's more of the originally recorded music pass thru without being clouded by noise. You're hearing more of what was originally recorded.
    I was astounded by the difference I was hearing. Noise simply maskes the music, where the AHB2 does not, it let's it all out pretty much like a straight wire with gain. I'll take the AHB2 everyday & twice on Sunday. Unless your retired then twice on Saturday cause everyday is Saturday.
