what are you running your LSiM 707 with ?
I didnt realize these are 88 sn sensitivity . I have an amp made with the ICE a1200as2 module which is good for 600 rms x2 but curious what kind of class A/B amp will run good on this amp as I might try another amp.
ive had the Crown XLS amps and my current amp is basicallto ,one them. im thinking a nice high current amp would do the trick
  • ohskigod
    ohskigod Posts: 6,505
    Those 1200as’s are hard to beat. This might sound crazy but I’m running 2 of them as monoblocks which means they’ll put out 1200 into that 4 ohm load.
    Listening to it now as I type and I did not expect this much improvement.
    Just a thought as those 707’s love power too
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • ohskigod
    edited October 2025
    Long story short I’ll keep some AB amps around but with the 1200 monos I am DONE
    You can go a DIY route for the second one and save some cheddar too.
  • MAZ
    MAZ Posts: 27
    nice!guess i will keep it then and maybe build another
    F1nut Posts: 51,746
    Don't pay Lou any mind, he's as deaf as a doornail ;)
  • mpitogo
    mpitogo Posts: 515
    Rotel RB-1590. 350 W/Ch (8 Ω) 648 W/Ch (4 Ω) has no issues driving them. I read a review in Europe published tests of the amp with the power cord melting current limiting circuit disabled and got insane numbers.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
    F1nut Posts: 51,746
    Since Rotel doesn't list the peak to peak current rating on their site do you know what it is?
  • mpitogo
    mpitogo Posts: 515
    It’s current limited to 15A but some folks are saying 34A or 50A here https://www.diyaudio.com/community/threads/rotel-rb-1590.380008/
    unfortunately I couldn’t find the original article I read about power.
    F1nut Posts: 51,746
    The current of one of my amps is rated at 160 amps. The power cord has never melted.
    Someone was pulling your leg.
  • skrol
    skrol Posts: 3,448
    160 amps! I imagine the neighbors know when you are listening; not because they can hear it but because they see their lights dim. Do you have your own nuclear power plant?
    Stan
    Main 2ch:
    HT:
    Other stuff:
    pitdogg2 Posts: 27,029
    Dilithium crystals brah
    F1nut Posts: 51,746
    skrol wrote: »
    10 gauge line on a dedicated 30 amp breaker.
  • Emlyn
    Emlyn Posts: 4,700
    88dB efficiency isn't really that demanding. I've had no issues cranking up LSiM707s with a Parasound A23. The LSiM tweeter is the main weak point on those speakers and those could blow with any amp if played too loud for too long. The racetrack style woofers are also unusual. I found the LSiM707s to not integrate the top and bottom sections all that well compared with other speakers, but no amp was going to fix that.
    I sold a Rotel RB-1090 (now RB-1590) years ago because, although it had plenty of power output, it wasn't as refined sounding as amps with half the power that I had access to. It was overkill. The Rotel RB-1080 (now RB-1582) to me was a better, maybe ideal, sweet spot class AB amp choice for most uses.
    F1nut Posts: 51,746
    BINGO!!!
