My 12 step program has gone awry
Must have clicked on something…
I guess as long as it’s here I might as well keep going.
Aaron
Enabler Extraordinaire
    pitdogg2 Posts: 26,921
    You're going to need more wood.
    heiney9 Posts: 25,395
    12 step programs are overrated. Can't wait to see the step by step build.
    SCompRacer Posts: 9,077
    You got that Bottlehead sale email too!
    You get them kits quicker now they are located in IL. :D
    EndersShadow Posts: 17,686
    It’s the crack….
  • ALL212
    ALL212 Posts: 1,644
    I’ve had enough crack. B)
    This one’s the Moreplay.
    Should I be concerned? This upgrade board is called out as the “claymore”
    Aaron
    Be afraid, be very afraid...
    edited November 28
    Just avoid squeezing the M57 clacker, if included with kit.
    I'm anxious to see an upgraded base.
  • ALL212
    ALL212 Posts: 1,644
    While pondering the plate color and base wood thought I’d start with the upgrade PCB.
    Aaron
  • invalid
    invalid Posts: 1,441
    Is this the Bottlehead preamp with a 6v6 power tube?
  • ALL212
    ALL212 Posts: 1,644
    Yepper.
    Aaron
  • ALL212
    ALL212 Posts: 1,644
    Paint job done.
    Aaron
  • ALL212
    ALL212 Posts: 1,644
    Enough for today.
    Not stock:
    Power switch is a Cherry, not a big deal but the one that comes in the kit tends to melt if you leave heat on it too long.
    Input terminals and the Goldpoint selector were pulled from a scrapped passive pre experiment that worked but provided no sonic improvements (and way less gain) then any other.
    I’m going to try and stream in the upgrade kit rather than build stock and then rip/replace.
    So far no additional cost but there are some upgrade caps on the way.
    Aaron
  • halo71
    halo71 Posts: 4,628
    I have the Foreplay II and to my ears and for the money. It is a great sounding tube preamp. Wish it had a remote control though.
    --Gary--
    edited December 2
    Next time you buy paint, check the expiration dates first. :D
    Looks good! I was going to do my Otari faceplate and rack mounts with Rust-Oleum Textured Black. The face plate cleaned up nice, so I was just gonna do just the rack mounts. I shook the can really good, it started spraying then the feed tube clogged. I just used the Behr old rubbed bronze paint I had used for the head cover and returned the black for a refund.
    Not my Otari deck, belongs to Nashou66 at AK, but this is what the textured black finish looks like.
  • ALL212
    ALL212 Posts: 1,644
    Can’t say I’ve had that kind of paint problem…yet!
    Power supply basics done. 330v DC where it should be. It’s just a bit high but I have no load at all on the transformer.
    Aaron
  • invalid
    Making progress.
  • ALL212
    ALL212 Posts: 1,644
    A bit more but have to stop as I’m awaiting some caps.
    So far voltage checks are good and I’ve yet to pick up the hot stick by the wrong end.
    Aaron
    What caps do you need? You bailed me out with some. If I can I will.
  • ALL212
    ALL212 Posts: 1,644
    Got some 2.2uf 250v film caps coming down from Madison- should be here tomorrow latest.
    Thanks fer the offer but I’ll wait it out. Best I do this slowly anyway
    Aaron
