My 12 step program has gone awry
Must have clicked on something…
I guess as long as it’s here I might as well keep going.
Aaron
Enabler Extraordinaire
    pitdogg2 Posts: 27,249
    You're going to need more wood.
    heiney9 Posts: 25,495
    12 step programs are overrated. Can't wait to see the step by step build.
    SCompRacer Posts: 9,121
    You got that Bottlehead sale email too!
    You get them kits quicker now they are located in IL. :D
    EndersShadow Posts: 17,719
    It’s the crack….
  • ALL212
    ALL212 Posts: 1,664
    I’ve had enough crack. B)
    This one’s the Moreplay.
    Should I be concerned? This upgrade board is called out as the “claymore”
    Aaron
    Be afraid, be very afraid...
    edited November 2025
    Just avoid squeezing the M57 clacker, if included with kit.
    I'm anxious to see an upgraded base.
  • ALL212
    ALL212 Posts: 1,664
    While pondering the plate color and base wood thought I’d start with the upgrade PCB.
    Aaron
  • invalid
    invalid Posts: 1,519
    Is this the Bottlehead preamp with a 6v6 power tube?
  • ALL212
    ALL212 Posts: 1,664
    Yepper.
    Aaron
  • ALL212
    ALL212 Posts: 1,664
    Paint job done.
    Aaron
  • ALL212
    ALL212 Posts: 1,664
    Enough for today.
    Not stock:
    Power switch is a Cherry, not a big deal but the one that comes in the kit tends to melt if you leave heat on it too long.
    Input terminals and the Goldpoint selector were pulled from a scrapped passive pre experiment that worked but provided no sonic improvements (and way less gain) then any other.
    I’m going to try and stream in the upgrade kit rather than build stock and then rip/replace.
    So far no additional cost but there are some upgrade caps on the way.
    Aaron
  • halo71
    halo71 Posts: 4,637
    I have the Foreplay II and to my ears and for the money. It is a great sounding tube preamp. Wish it had a remote control though.
    --Gary--
    edited December 2025
    Next time you buy paint, check the expiration dates first. :D
    Looks good! I was going to do my Otari faceplate and rack mounts with Rust-Oleum Textured Black. The face plate cleaned up nice, so I was just gonna do just the rack mounts. I shook the can really good, it started spraying then the feed tube clogged. I just used the Behr old rubbed bronze paint I had used for the head cover and returned the black for a refund.
    Not my Otari deck, belongs to Nashou66 at AK, but this is what the textured black finish looks like.
  • ALL212
    ALL212 Posts: 1,664
    Can’t say I’ve had that kind of paint problem…yet!
    Power supply basics done. 330v DC where it should be. It’s just a bit high but I have no load at all on the transformer.
    Aaron
  • invalid
    Making progress.
  • ALL212
    ALL212 Posts: 1,664
    A bit more but have to stop as I’m awaiting some caps.
    So far voltage checks are good and I’ve yet to pick up the hot stick by the wrong end.
    Aaron
    What caps do you need? You bailed me out with some. If I can I will.
  • ALL212
    ALL212 Posts: 1,664
    Got some 2.2uf 250v film caps coming down from Madison- should be here tomorrow latest.
    Thanks fer the offer but I’ll wait it out. Best I do this slowly anyway
    Aaron
  • ALL212
    ALL212 Posts: 1,664
    Getting close…
    Some checking to do yet and B+ wiring changes to accommodate the upgrade board.
    Lose mogami wire there just to size up the paths needed. One output will be non amped for a straight to headphone amp connection.
    Aaron
  • ALL212
    ALL212 Posts: 1,664
    Huh.... how about that - it works! On the first try yet.
    Aaron
    Hey, nice work. Did you have to look at two sets of instructions to apply the update in the initial build?
    AI was surely involved....
  • ALL212
    ALL212 Posts: 1,664
    SCompRacer wrote: »
    Ya… Bottlehead doesn’t like you streaming in upgrades. Should it not work it will become very difficult for them to assist and I’ve seen them request the builder go back to stock.
    I print (in color) both manuals and figure out what I can leave out in the basic build and where I need to go in the upgrade manual. I still got ahead in the basic build but in order to do volt checks sometimes you have to do basic and then back it out.
    I picked up a 27” monitor in an auction. That helped a lot as I have it right at my work desk. I can blow up directions so the neighbors can read them!
    One output is setup to go from selector straight out so I can run a headphone amp out of it.
    Aaron
    You and your tube fins, I like to see the fire in the bottle myself. It's like watching a bonfire 🔥🔥
  • ALL212
    ALL212 Posts: 1,664
    SCIENCE!!! I’ve been blinded!
    Aaron
  • skipshot12
    skipshot12 Posts: 2,091
    Have never owned any tube equipment but me think's those heat sink fins are a good idea.
    Does help in extending tube life via cooling?
    Have also read about some folks damping the tubes for vibrations.
    Do those fin things help with that too?
    Looks cool.
    Skip
  • ALL212
    ALL212 Posts: 1,664
    In theory - yes to both.
    Extending the life of a 50,000 hour tube that I run for 100 hours a year might seem worthless but what the heck!
    Aaron
  • invalid
    I would try without those things around the tubes, it will probably sound better.
  • Emlyn
    Emlyn Posts: 4,812
    I found the Pearl Tube Coolers (not sure if that's the brand above) to deaden the sound on a preamp but didn't have a negative effect on the sound from a 6550 tubed power amp. They were inexpensive enough to try out, at Parts Connexion recommendation, and stash away if not being used.
