SDA CRS+ Crossover recap
  • DeRod
    DeRod Posts: 249
    @F1nut I agree, I should upgrade those stands a bit. They do have some rubber pads on the feet and on the tops where the speaker sits.
    I think the next thing I would like to do with these is a really nice veneer. That dyed maple you showed me a while back would look crazy on these.
    "Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb.
    heiney9 Posts: 25,469
    Nice work. Do yourself and your ears a favor and get rid of the sl2000 tweeters and get the RD0-194's. They are plug n play designed by Polk to "fix" the issues the sl2000 has.
    pitdogg2 Posts: 27,126
    4.1tl mod.......
  • DeRod
    DeRod Posts: 249
    edited November 2025
    @heiney9 I have a pair of RD0-194, but I just wanted to listen to the speakers as is with the original tweeters. I'll probably switch the tweeters out next week to hear the difference. For some reason the SL2000 doesn't seem as annoying in the SDAs as in the monitors.
    @pitdogg2 with the 4.1tl mod what are the benefits? I've been told that to upgrade to the RD0198-1 is relatively easy as well.
    It gives you the ability to use the RD-0198 tweeter. 5.8uf cap across the 2.7 ohm resistor and add a large faston on white ground wire to tweeter.
    https://us.v-cdn.net/5021930/uploads/attachments/1/8/5/1/1/26710.pdf
    Just remember which ever RD0 you choose, give them ample break in time before forming an opinion.
  • DeRod
    DeRod Posts: 249
    The RD0-194 I have currently reside in a pair of monitor 5Bs I’ve been playing with.
    BTW - Tweeters don’t break in. 😂😂 they sound exactly the same as when I first bought them.
    The woofers on some of my other more expensive speaker did require some break in time but the Audax tweeter those came with sound exactly the same as the first day.
  • Check out these two threads which show how WMG and xschop approached the issue of backwave control in these. Also check out how WMG did his boards, not that yours aren't fine 😉
    https://forum.polkaudio.com/discussion/169838/sda-crs-crs-something-different/p1
    https://forum.polkaudio.com/discussion/177189/take-a-guess/p1
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • WMGs crossover above was the tl mod. You could use that as a template if you ever decided to go that route.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • mwk1001
    mwk1001 Posts: 5
    edited December 2025
    This has long been on my list of diy upgrades, now retired I think this has my name all over it. Any chance you have the source / part# for the parts, I would like to do the same mods, I blew out the woofer years ago and replaced them and updated the tweeter to SL3000 ?? I believe ... cant find the paperwork any longer. But did have the schematic update for the newer tweeter. ru8wsvz4c8oj.jpg
    VR3 Posts: 29,457
    How tall are you?? 👀👀😁😁
  • Gardenstater
    Gardenstater Posts: 4,785
    @mwk1001 When I zoomed in on your photo I didn't see any foam ring so it must be that you bought the RD0198-1 silk dome upgraded ones. Check and make sure you have RD0198 (5.39 Ohms) and not RD0194 (6.6 Ohms).
    You already did most of the homework by grabbing the schematic. I think if you read that link above he said that he only did the low pass inductors for the midwoofers and he used Jantzens. you could find them maybe at partsconnexion.com. He used Sonicaps from soniccraft.com which are highly favored around here, for all the caps and Vishay/Mills 12 W resistors.
    Oh, for the sub bass inductor he used Erse Super Q? For that you will have to look at Uscoils.us.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • mwk1001
    mwk1001 Posts: 5
    " When I zoomed in on your photo I didn't see any foam ring so it must be that you bought the RD0198-1 silk dome upgraded ones. Check and make sure you have RD0198 (5.39 Ohms) and not RD0194 (6.6 Ohms)."
    Thanks for that. I was not sure after going thru the threads, my purchase doc was lost but the schematic was saved in 2016 so that is when I upgraded them. I found the mills resistors and went with Clarity CSA's for tweeter/midrange Clarity PX for the SDA 6.5 driver (2x20)
    Some fun reading the humble homemade HiFi capacitor page and balancing crazy money against my enjoyment of the CRS+ I had sonicap/mundorf supreme in my head but I'll try these CSA/PX's see how it goes.
    @vr3 How tall are you?? Yeah I know, The "dream" was to have that wall like a real library with rolling ladder and all ... Then they would have had a custom space carved out with room in the rear a tad lower :) . But that has not happened yet ... you know we have only been here 20 years ... I have a nice woodshop but everyone else's stuff seems to come first !! I even have a tiny 3 axis milling machine that I made the baffles for my office speakers from a planet10 box design and CSS fr-127 full range drivers hooked up to an Ncore 2 channel DIY..
    Found the box of old drivers and a slip of paper saying they were the RD0194-1 I'll double check but odds are this slip is correct I have 0194-1. So no 5.8 cap ?
    The things getting in the way ....
    Post edited by mwk1001 on
  • I guess you still need to check the DCR of the tweeters to see which ones you purchased. If they said SL3000 compatible or something like that, you probably have the RD0198-1. That shouldn't be a perfect match for your unmodded crossover without doing the tl mod, which you are planning to do.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,859
    No need to bother measuring. The easy way to tell is the tabs on the RD0194-1 are the same size while one tab on the RD0198-1 is bigger than the other.
  • Grr. Off it comes again. I think I'll do both since the photo I took I cannot make out the tabs well enough ! if 194 i'll probaly just get the 198's in for a penny .....zd90h7xipty0.jpg
    F1nut Posts: 51,859
    Same size tabs.
  • mwk1001
    mwk1001 Posts: 5
    Same size tabs and 7.5 Ohm across the unplugged driver ??
    Probably my meter jumping around alot but plugs are clearly the same size and all measures are 6.6 ( one ) the rest higher ...6vfmmu8dalbu.jpg
    F1nut Posts: 51,859
    Yep. I don't know what meter you are using and it doesn't matter. If the tabs are the same size it is the RD0194-1.
  • mwk1001
    mwk1001 Posts: 5
    I sent a note to polk parts and I see some about ... so 0198's it will be .
    mwk1001 wrote: »
    Just call the CS number and mention you're a member here at club Polk.
    1-800-377-7655
    Depending on the CRS model the RD-0198 is not drop in compatible, there is some XO work involved to work correctly.
    edit: I see you have the correct schematic to use them.
  • skipshot12
    skipshot12 Posts: 2,022
    Hey Jesse,
    What's this and where?
    "Replace the broken plastic standoffs with metal hex standoffs."
    Does that also include my SDA SRS's?
  • lms
    lms Posts: 54
    Are these crossovers specific to a certain year on crs speakers because mine look nothing like this?
    Also, not sure if it was brought up, but don't forget to glue the drivers.
    If you set them up in a room where they have more than 3 feet to the side wall, let the real magic begin. I'll never forget when I hooked my crs speakers for the first time, but I had 10 feet on either side. Sold all my other ones as I was hooked.
    F1nut Posts: 51,859
    skipshot12 wrote: »
    Hey Jesse,
    They are the white plastic pieces supporting the board.
    No.
    skipshot12 wrote: »
    Hey Jesse,
    Original standoff from Polk were a plastic/nylon that the crossover snapped over on either the binding cup or board above the binding cup. Most of us reused them or bought longer nylon or metal hex standoffs to use for the larger caps we may have soldered under the board due to size constraints on top.
    On the SRS-SDA yours is behind the aluminium XO plate you see on the front of the speaker.
    xschop Posts: 5,223
    Bump for the current CRS builders. I tried finding an old pic/post where I found 3.5" long styrofoam cones from the hobby store that worked perfect for the stand-off foam mod.
  • DeRod
    DeRod Posts: 249
    Made new ends for my SDA cable. Fits much better now.
  • DeRod
    DeRod Posts: 249
    skipshot12 wrote: »
