Wanted-Streamer
I just signed up w Qobuz so I need a streamer with Q Connect built in....or whatever it is called. Would like to keep this purchase to 500ish. PM me what you may want to sell. Thanks Dudes...
    nooshinjohn Posts: 25,995
    My Simaudio 680d would get the job done nicely.
  • kevhed72
    kevhed72 Posts: 5,160
    edited October 2025
    For 500.00 it would be unbelievable. I was drooling over it earlier....very nice.
    treitz3 Posts: 20,106
    A BlueSound Node 2 will do that. You can pick them up used for probably half your budget, shipped. FWIW.
    That's what started my streaming journey.
  • Conradicles
    Conradicles Posts: 6,375
    If interested Kev, I have an extra Wiim Ultra like new. I'll PM you.
  • gyosa
    gyosa Posts: 770
    I second the WiiM Ultra … great choice …
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    EndersShadow Posts: 17,719
    I dig my WiiM Pro Plus (model down from the Ultra).
    Gonna perhaps buy some of the minis to replace my chromecast audios.
    heiney9 Posts: 25,496
    BlueSound Node 2 or 3 and get the super simple to install linear supply board and a good 5V 3A linear power supply and you'll be golden.
    I only sold mine to get the Roon Nucleus One which is also a server, otherwise I would have kept my BlueSound Node 3 w/lps.
  • maxward
    maxward Posts: 1,718
    I bought the node from @heiney9 . I got an LPS on USaudiomart because H9 kept his. It sounds great especially since Spotify now has lossless available. Looking to try Qobuz sometime this winter.
  • kevhed72
    I am enjoying Qobuz and looking forward to trying out Q Connect on the WiiM Ultra. My Bluesound Nano is getting moved to the living room so I never have to listen to FM on my Rotel Receiver anymore. FM radio is such a wasteland nowadays.
    Toolfan66 Posts: 18,170
