polk 707 "6x9" speaker repair
Finally got me a pair of these in cherry. were put up in storage for a while and somehow there is a hole in the surround of one of the 6x9 drivers. not big. best way to repair it?
  • odcics2
    odcics2 Posts: 396
    New surrounds
    F1nut Posts: 52,381
    A rubber cement used for tire repairs should do the trick.
  • MAZ
    MAZ Posts: 29
    I was thinking id get a tire patch and cut very small piece and put one on each side
    F1nut Posts: 52,381
    MAZ wrote: »
    Bad idea, too much weight in one spot and the flex will be affected.
  • MAZ
    MAZ Posts: 29
    MAZ wrote: »
    what about on just one side? the hole is smaller than pinky fingernail. about half that. it plays now just like it is but at higher volume it might. afraid it might tear
    Toolfan66 Posts: 18,412
    edited September 2025
    MAZ wrote: »
    MAZ wrote: »
    Just use the glue as he suggested..
    Can you post a pic of the tear?
    Viking64 Posts: 7,805
    Toolfan66 wrote: »
  • odcics2
    odcics2 Posts: 396
    That poor guy would be sobbing today. :'(
