The dumbest audio-related claims you’ve heard.
daddyjt
daddyjt Posts: 3,028
I was having a discussion on another forum about how impressed I am with the sound out of my repaired Levinson amp, when some guy wades in and says “all amplifiers sound the same, as long as the output power and distortion numbers are similar…” There was a time when I would have argued the point, but I’ve learned there just isn’t much use in trying to educate the willfully ignorant.
What are some of the most ignorant claims you’ve heard? (Besides “cables don’t matter”, lol)
― Aleksandr Solzhenitsyn
    nooshinjohn Posts: 25,872
    edited August 31
    These "all sound the same" types are simply jealous that people have things they can only dream about,,,
    Post edited by nooshinjohn on
    F1nut Posts: 51,660
    You need an amp with a high damping factor... ummm, nope.
  • motorstereo
    motorstereo Posts: 2,317
    edited August 31
    I'm being truthful when I say I could easily compile a list from myself from my early days in this hobby; live and learn.
    Viking64 Posts: 7,502
    Bon Jovi sounds good.
    heiney9 Posts: 25,395
    That speakers put out watts. Something along the lines of "your bookshelf speakers put out 50 watts, my Cerwin Vegas put out 200 watts". This comment is made regardless of reciever output. As if the speakers are putting out the watts not the amplifier/the receiver.
  • Emlyn
    Emlyn Posts: 4,616
    Digital audio is just ones and zeroes.
  • daddyjt
    Yea, I too cringe a bit when I consider some of my firmly held beliefs during my early years in this hobby.
    treitz3 Posts: 19,942
    edited August 31
    Emlyn wrote: »
    Took the words right out of my mouth. That's the one that really gets my goat. Not that I really care if someone thinks that or not, it's just that it is these types of folks who are seemingly the most vocal about their point of view. They don't seem to want to accept any other point of view. They kind of remind me of the Ethernet cable guys.....you know the type.....they can't make a difference because it's all 1's and 0's. Audiogon is fraught with people like this (as well as the other naysayer type of people).
    It makes it frustrating for folks who would really like to know the differences, along with the ones who really would like to learn how it all works. They have to sift through all the BS and makes the signal to noise ratio incredibly low. That's when the mudslinging usually starts. So basically, nobody learns anything.
    That's one of the reasons I like this forum. We don't tend to put up with this type of nonsense.
    As harsh as this may sound, I gotta agree with that. I see it like this. They can't afford, or don't want to afford anything nicer than what they have, so they seek out others that share their own point of view to justify them not having to spend the money.
    daddyjt wrote: »
    "I know because I was an electrical engineer for 40 years" - Well, that right there lets me know you are on the wrong side of the fence and that I need not listen to a damned thing you have to say. It's pointless. The ones that truly are on the right side of the fence would never say that. They just get right down to business. At least that's my experience with both in person and online engineers...YMMV
    SCompRacer Posts: 9,077
    edited August 31
    In areas we can control, you get what you accept.
    With ethernet cables, it's not just the wire but the termination. Back when I was doing DIY DAC's, I modded a Sony 3910 to export PCM and DSD to my DIY DAC. I had dropouts with DSD using some cheap Cat6a patch cords while PCM played fine. I purchased a couple patch cords from Blue Jeans cable. Not that expensive either. He tests them to make sure the cables performed properly.
    A naysayer replied two different CAT6 cables will perform the same.
    Kurt of Blue Jeans jumped in...
    "I saw this thread and thought I'd jump in and comment on this; I'm Kurt Denke, owner of Blue Jeans Cable in Seattle WA, the manufacturer of the patch cord used by SCompRacer.
    I agree with you, in principle, but I strongly suspect that the speed difference SCompRacer reports in his file transfer is for real. The surprising thing is that HUGE numbers of patch cords on the market fail their stated spec, and when we tested 20 different so-called Cat 6 and 6a patch cords from a variety of retail vendors on our Fluke DTX certification tester, sixteen failed their stated specs, and eleven of them not only failed their stated spec, but also failed the Cat 5e spec.
    So, what is happening, in my view, to a lot of users is that they are indeed seeing different performance with different patch cords; this would be inexplicable if we assume that all of the patch cords meet spec, but once we realize that many of them fail it miserably (one "Cat 6" cable we tested failed the 5e return loss spec by 8 dB!), the likelihood of real-world differences in use really does loom large."
    pitdogg2 Posts: 26,918
    Emlyn wrote: »
    I'll go one better, "digital ready speakers" SAY What!?
    SCompRacer wrote: »
    With ethernet cables, it's not just the wire but the termination. Back when I was doing DIY DAC's, I modded a DENON 3910 to export PCM and DSD to my DIY DAC. I had dropouts with DSD using some cheap Cat6a patch cords while PCM played fine. I purchased a couple patch cords from Blue Jeans cable. Not that expensive either. He tests them to make sure the cables performed properly.
    Correction in bold
    Three letters say it all... ASR
    Amir and his ilk are the laughing stock of all things audio, except the measurement crowd. Nobody who is truly into this hobby and wants what's best in audio pays any attention to them.
    edited August 31
    Correction in bold
    Thx! Yeah, Denon. I had a Sony but didn't mod that one, ModWright did. Still have the Denon 3910.
    Post edited by SCompRacer on
  • invalid
    invalid Posts: 1,439
    Emlyn wrote: »
    1's and 0's mean nothing to digital audio or computers for that matter.
  • gmcman
    gmcman Posts: 1,839
    First thing I thought of when I read the OP's post.
  • daddyjt
    A little more detail on my run-in…
    I was told that I wasted my time repairing/refurbing the Levinson, because it’s old and outdated. I was told I should “get with the times”, and get something like the Topping PA7 (below), because “watts are watts”, and it doesn’t matter if the amp is $500 or $5,000, as long as the distortion numbers are good.
    10% distortion and only tested at 1kHz, give me a freaking break!
    Not enough current to stun a mouse.
    and a 220v power supply...
    VR3 Posts: 29,383
    I have a halfway decent digital amp that puts out plenty of power, it just only sounds ok compared to a quality class a or ab amp. I guess if you didn't know what you were missing it could be ok 😅
  • daddyjt
    VR3 wrote: »
    I bought a little Fossi (sp) 50w x2 amp for my daughter in her room. It’s about the size of 4 DVD cases stacked together, and it runs a little pair of NHT bookshelf speakers, and sounds surprising good. However, it isn’t in the same league as an Adcom, Carver or Parasound amp, let alone the likes of McIntosh or Mark Levinson. Hell, it’s not even the same sport…. But as you point out, if you don’t know - but these ASR types should know better.
    "Since speakers that conform to these parameters will present the sound in much the same way we can already move away from thinking that it is essential to listen to them before making the choice."
    -ASR
  • drop1
    drop1 Posts: 66
    edited September 2
    "Cables don't make a difference"
    I have little experience experimenting with cables. But I reject the claim. It's easy to make the claim in one direction. But it should be easy to conceive the idea that a poor quality cable can diminish the sound quality in your system.
  • Jstas
    Jstas Posts: 14,965
    I've heard stuff that people say that I don't agree with.
    I've heard stuff people say that others don't agree with but I do.
    I find that it's not the experience level that matters as much as the understanding of what is producing that experience for the listener.
    daddyjt wrote: »
    While, technically, this is true...on paper, reality is not so cut and dry. This very same discussion about all amps sounding the same has been had here. "Discussion" being a kind way of saying "knock down, drag out fight".
    When folks make de facto statements like that, though, I have found more times than not that it's not coming from jealousy or inexperience or some other sort of social based construct. It is coming from rationalization instead of rational thought, though.
    OK, so you made a change in your stereo and you heard a difference. Cool. Maybe you made a change and didn't hear a difference? Alright then, that's cool too.
    But do you understand why? If you don't understand why are you going to try to learn why?
    There are so many variables to account for in those changes. Everything from the environment you are listening in all down to the acid content of the PCB that your amp is built on can affect the reproduction of the sound. You can go crazy fretting over every little detail if you want.
    But the biggest factor of them all lies between your ears. Whether you can grasp the concept that wires do matter because gauge, material composition, length, termination ends and even jacketing can affect the conductivity and noise floor of the component and it can manifest in audible changes. Sometimes it doesn't for some people. That doesn't necessarily mean that wires don't matter, it just means you can't hear a difference. Mr. Grand was a big "wires don't matter" guy but Mr. Grand also had permanent hearing loss from decades of serving his country as the boom operator in a KC-135. He couldn't hear much above about 11,000 Hz. So changes I could hear when wires were swapped out he could not because they happened in the ranges where his hearing was impaired. Does that mean wires don't matter? Nope. It just means that wires didn't matter to him because he could not realize the benefits.
    There's always the placebo affect too, where you are expecting a change so even if there wasn't an audible one, your brain is saying there was so you can rationalize an expensive purchase.
    The biggest problem, though, with all of it is the stigmas forced on everyone over it. It gets very cliquish and you're either a "believer" or a "non-believer" and then sorted into a faction perpetually cursed to do battle with the opposing faction for the entirety of your hobby activity.
    Then you get the forceful rationalizations where folks make brash, broad claims like your amp doesn't matter or cables don't matter and it's often not coming from an empirical evidence stance but rather a "Holy heck, buddy, will you shut up about the amp specs and just listen to the music already!" or maybe they don't have the money to spend on an amp and they want to avoid the peer pressure or ridicule over their decisions? Any way you cut it, it's not always willful ignorance but it is always ego based. Nobody likes being told they are wrong, especially when personal evidence is contrary to that idea. Additionally, nobody likes hearing about how their rig is junk because it doesn't meet someone else's standards or getting mocked for it either (like Emotiva owners, anyone?).
    I think that, right there, is the stupidest thing I have ever heard in this hobby of ours.
    Do you like listening to your stereo? I like listening to mine. Most would scoff at some of the very plain and basic rigs I've had. I don't care though. I like it and that's all that matters.
    Some of us just like listening to the music and they are content with what they have. More power to them, I'm sure they have way more beer money than others because they don't swap gear like they change underwear.
    Some of us like the nerdy, science side of the hobby and strive to find out at least WHY things happen the way they do when something changes even if they can't afford to make the actual changes every time. Gives them something to strive for, though!
    But the whole hobby is relative and it's based completely on a subjective consumer trying to be objective about a subjective topic.
    When we mock others or dismiss them for their thoughts and experiences being different from ours, we really do hurt the hobby and, honestly, ourselves. Sometimes there are people who are very closed off and just won't listen to reason. You can't reach/help those but the rest of us? What's our excuse to laugh at and torment others over their difference in experiences? We should be learning from each other to deepen experiences and understanding on all sides.
    So, I said all that to say this. The stupidest thing I have ever heard of in this hobby is the superiority complex based around a perceived moral high ground that deliberately excludes those who don't know/understand from actually knowing and understanding. Especially when the person thinking they hold that high ground has even less experience and understanding than the person they are holding that high ground over.
    A close second is the baffling questions from audiophiles on why non-audiophiles dislike them. For the answer to that question, see the previous statement on what I think is the stupidest thing I've ever heard in this hobby.
    YMMV
    Expert Moron Extraordinaire
  • invalid
    edited September 3
    [quoteBut as you point out, if you don’t know - but these ASR types should know better.
    [/quote]
    Wait, Amir owns Levinson amps?
    VR3 Posts: 29,383
    His whole system was or is levinson
  • bcwsrt
    bcwsrt Posts: 2,361
    @Jstas, all the reasons why I like it here. Hardly any of the negative stuff that you so well summarized, at least in my experience.
    Brian
    One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM
    bcwsrt wrote: »
    Your wires suck......
    edited September 3
    bcwsrt wrote: »
    Just because he uses broken coat hangers is no reason to denigrate him or his rig. Besides, everybody know that all you need for a long run of wire is 32 gauge, single strand aluminum for adequate transmission. Wires do not matter!
  • ken brydson
    ken brydson Posts: 8,980
    bcwsrt wrote: »
    Yeah but he's using plastic hangers. I read on another forum that it didn't sound good...
