How to remove L800 tweeter
warlocks1
warlocks1 Posts: 1,284
edited July 2025 in Speakers
I believe the non SDA tweeter on the right L800 tweeter is blown
How do you remove them from the cabinet?
Disregard. I figured it out!
Answers
    VR3 Posts: 29,756
    A little bit of energon and a whole Lotta luck, said in my best Optimus prime voice
    Glad you got it figured out! 😁
  • Unknown
    edited July 2025
    txcoastal1 Posts: 13,520
    VR3 Posts: 29,756
    SDA tweeter is a thing, it is rolled off around 5khz if I remember correctly - it doesn't play full range
    nooshinjohn Posts: 26,160
    txcoastal1 wrote: »
    He got this... B)
