How to remove L800 tweeter
warlocks1
warlocks1 Posts: 1,284
edited July 2025 in Speakers
I believe the non SDA tweeter on the right L800 tweeter is blown
How do you remove them from the cabinet?
Disregard. I figured it out!
Answers
    VR3 Posts: 29,549
    A little bit of energon and a whole Lotta luck, said in my best Optimus prime voice
    Glad you got it figured out! 😁
    pitdogg2 Posts: 27,309
    edited July 2025
    I was told there's no SDA tweeter as they both operate the same.
    txcoastal1 Posts: 13,519
    VR3 Posts: 29,549
    SDA tweeter is a thing, it is rolled off around 5khz if I remember correctly - it doesn't play full range
    nooshinjohn Posts: 25,998
    He got this... B)
    β€œWhen once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson
