Bi-WIring Polk L800s for SDA
Recently, I purchased the Polk L800s. After exploring various forums about optimizing performance for the SDA, I learned I needed a single-ended, non-differential amplifier. As a result, I bought the Marantz PM-KI Ruby, which fits my budget and provides enough power for my listening needs. However, I purchased the Parasound A21+ based on a friend's recommendation before I bought the Marantz PM-KI Ruby. As it turns out, the Parasound A21+ is not a single-ended, non-differential amplifier. My goal is/was optimal performance for SDA within my budget. So my question is this: Should I use the Marantz PM-KI Ruby and the A21+ for bi-wiring? Will the SDA still function properly if I use the Marantz PM-KI Ruby for the highs and mids, while using the Parasound A21+ for the woofers? I considered using the A21+ for the woofers because it has a damping factor around 1000, which suggests I could achieve tighter and more controlled bass, even at lower volume levels. I'm also aware that the two different amps could cause different sound environments, but would that even matter for the woofer/base frequencies? I'm new to the world of high-fidelity audio. Any advice would be appreciated. The Marantz PM-KI Ruby is expected to arrive in a few days, so I will conduct a test to determine if there is a noticeable difference. I wanted to know if anyone has information on this topic now.
You are asking about bi-amping, not bi-wiring. Regardless, the answer is no.
BTW, the Ruby (excellent) is an integrated amp while the A21+ is a power amp only. Sell the A21+.Political Correctness'.........defined
President of Club Polk -
I don't believe the parasound A21+ amplifier is fully balanced from input to output, it has a single ended output stage.
Agree, you can have XLR or balanced which ever way you want to refer to them, inputs and outputs and not be dual differential. -
I forgot to address this.I considered using the A21+ for the woofers because it has a damping factor around 1000, which suggests I could achieve tighter and more controlled bass, even at lower volume levels.
The difference between a damping factor of 50 and 1000 is so tiny that it is laughable. In addition, to obtain a high damping factor generally requires a large amount of negative feedback, which may or may not be a bad thing.Political Correctness'.........defined
Thanks for the correction and comments!
Listen to F1….the prophet speaks the truthI plan for the future. - F1Nut
HAAAARRRRRRRRPolitical Correctness'.........defined
Just use the Ruby integrated on it's own, it will be more than enough.
I bi-amp and having been doing it since 2019. I find that the L800s love power.
- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
- Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.1 B&W Formation Duo and Bass
- Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
- Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
- Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
Mono-blocks are the way to go.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
