Worm clamps worth a damn...
treitz3
treitz3 Posts: 20,121
Man, I haven't been this frustrated in a while. Simple thing. Differing sizes. From 24" down.
These should be a $2 to $3 each, MAX cost. The prices I am seeing are around $23 to $45!!! (per)....plus shipping!
WTF?!!!!!??????!!!!
Where can a guy who needs them get a decent (preferably SS) worm gear clamp? From 24" to maybe 8"?
    VR3 Posts: 29,550
    Yeah, I saw those....but I don't trust Amazon for much. It may "say" they are stainless steel, but it's probably cheap Chinese crap. I now they aren't supposed to be over torqued, but they at least have to do their job and clamp a hose or air filter solidly!
    If I can't find a decent worm clamp, are there any alternatives that you know of? This is obviously for the engine bay, so extreme heat and other conditions will be present.
    VR3 Posts: 29,550
    Look here
    https://www.hoseclampkings.com/
    No affiliation
  • skipshot12
    skipshot12 Posts: 2,092
    edited July 2025
    Have you looked @ Norma Clamps out of Germany?
    Looked @ Skandvik.... loved their stuff on my Dolmar chain saws.
  • tonyp063
    tonyp063 Posts: 1,137
    West Marine is generally my go-to for SS parts
    https://www.westmarine.com/search?q=hose clamp
  • motorstereo
    motorstereo Posts: 2,367
    I picked up a big assortment of nice stainless hose clamps years ago at a yard sale for short money so I had no idea they were that expensive now. I did get sticker shock when rebuilding my boat trailer and had to buy some some square shackle clamps. Those things were stupid expensive for the ones I needed at the local autozone.
    Believe it or not? There are 2 worm clamps that threw a plethora of codes on my truck. Since the OP on this thread? I tested the truck tonight throwing no codes. Intake issues. It all boiled down to those cheap Chinese crap that they sell us.
    I ordered the 12" off of Amazon WC's, right? What did they send me? 4 feet or longer worm clamps that I can't even shorten to fit!
    It's time to go real. Thanks for your suggestions.
    VR3 Posts: 29,550
    The ones I linked were 12 ft if that's the one
    Naw, the ones I got were listed as 12". On the label? Made in China. I bought them for a temporary fix. Waste of money.
    VR3 Posts: 29,550
    Gotcha, yeah Amazon is definitely a caveat emptor situation
    pitdogg2 Posts: 27,332
    Why can't you shorten? I've used a pair of Subarus to shorten some that were too long.
    Because the cut out portions for the worm gear itself were missing for the first foot and a half. Stupidity beyond belief.
    Next up, Auto Zone for a temporary fix. Got a 3 pack. Will go marine grade, HD for the permanent fix. It's amazing to me....such a simple thing that has one job...cheap Chinese crap. Can't even seal an intake properly.
    VR3 Posts: 29,550
    You need to find one that's been quantum stocked and cryo treated!
