McIntosh MC40 Find
skrol
skrol Posts: 3,464
edited May 2025 in 2 Channel Audio
I may have an opportunity to get a single Macintosh MC40 that is in need of refurbishment. It blows its fuse immediately when power is applied.
It was actually used in a test equipment rack to drive the coil of a magnetic torquer bar for the Hubble. I am not sure if I can actually get it, but if I can, how difficult would it be to find another to match?
Stan
Main 2ch:
HT:
Other stuff:
    mhardy6647 Posts: 35,241
    Not uncommon. Not inexpensive.
    nooshinjohn Posts: 26,002
    Are you certain of it's connection to Hubble? Curious to understand how a Mcintosh amp could have been involved in building a space telescope.
    edited May 2025
    The Mac amps, including the MC-40 and MC-60, were widely used in engineering and scientific applications for many years (e.g., building shaker tables, which essentially use a low-frequency oscillator and a big audio frequency power amplifier). There were commercial versions of most, with even plainer cosmetics, for instrument use, though (and FWIW). Hubble was being designed and built when I was in college (the Space Telescope Science Institute was opened at JHU when I was an upper class UG or early grad student), so it's entirely possible.
  • skrol
    skrol Posts: 3,464
    edited May 2025
    I work on Hubble. The rack said what it was for and even had a test log book. I suspect that it predated HST based on the age of the amp ('62 - '69) and the other components. It was likely used for spacecraft prior to HST development.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skipshot12
    skipshot12 Posts: 2,092
    That’s really interesting……
    I never knew audio amps were used for things other than audio.
  • ManceJoan
    ManceJoan Posts: 1
    That’s a pretty cool piece of history — using it for Hubble-related testing is wild. Matching another MC40 can be a bit of a hunt since they’re not super common, especially in good condition. They do show up occasionally on eBay, Audiogon, or in collector groups, but pricing can vary a lot. Just make sure any second unit you find has similar transformers and cosmetic condition if you want a true match.
