Valvo ECC82
I am looking for Valvo Hamburg ECC82/12AU7 tubes with the following attributes:
1954-1956
Printed on bottom: D* K6*
Foil D-Getter
Long Plates
Thank you
Ike
    pitdogg2 Posts: 27,190
    edited April 2025
    Good luck! True Valvo made in Germany long plate Valvo tubes go for hundreds of dollars a piece. They are very difficult to acquire.
    Most of the early Valvo's I've seen had large slanted O getters.
    Heres a 1957.
    https://www.ebay.com/itm/267230453207?
    You see many holy grail tubes listed from Vietnam. I do not trust those sellers personally.
    https://www.ebay.com/itm/165064310833?
  • ike1985
    ike1985 Posts: 2
    Yea I'm not ordering from Vietnam lol. Yea i know what they go for, was hoping some guys here wanted to offload.
    edited April 2025
    ike1985 wrote: »
    Maybe after you get 100+ posts under your belt.
    heiney9 Posts: 25,488
    These are the rarest and hardest to find Valvo ECC82's. Even in the links Ivan posted, they don't show the tube codes. I don't purchase tubes without knowing the tube codes.
    I have a quad of the D* K6* Valvo's one tube is a bit noisy. I've been trying to replace the noisy one but have had no luck in finding a reasonably priced single or a reliable seller.
    In my listening comparison they sound so similar to the 1956/57- K62 D6* of which I have (2) quads, I sort of stopped my hunt. Same construction from 1956 & 57 but the codes are on the side glass not between the PINs.
    Still outrageously priced, but a bit easier to find. I did all my tube buying about 12-15 years ago. I can't believe how much prices have sky rocketed for the old tubes (supply and demand). Glad I have my stash and no plans to off load anything at this point.
    Toolfan66 Posts: 18,140
    heiney9 wrote: »
    What’s your addy? I will bring the duct tape and shovel.. 🤣
