Retina issue
Eyesight got blurry a few months ago. The vision center referred me to
A retina specialist. After scans, they sent me to my doctor immediately.
My blood pressure was through the roof. So I went on some serious
Blood pressure meds. I just revisted the retina specialist yesterday.
The retina scans showed reduced swelling, but they have started me on
Treatment. Shots in the eyeballs. Yuck. Numbing agents, multiple
disinfectant rinses, and then the shots. The worst part comes later
when the numbing agents wear off. About 18 hours of itching, burning
and a whole lot of eye watering.
The good news is these guys are supposed to be the best in the business.
And they are just around the corner.
The strange part is I didn't feel bad when my blood pressure was high.
The meds are kicking my behind. Hopefully the situation will improve
enough to dial down the meds. Getting old isn't for wusses.
    mhardy6647 Posts: 35,555
    Mrs. H has had a remarkable number of eye issues, starting with a giant retinal tear in (IIRC) Dec. 1998 (and another, much more minor, tear almost exactly a year later in the other eye).
    The stuff they can do with eyeballs nowadays is nothing short of astonishing.
  • OleBoot
    OleBoot Posts: 3,138
    sucks2beme wrote: »
    Are you diabetic?
  • sucks2beme
    sucks2beme Posts: 5,702
    Doctor confirmed that too. And high cholesterol.
    So major diet changes as well. But the blood pressure
    seems to have been the major cause. I retired two years
    ago. I spent too many years working myself ragged..
    Some days I didn't even get to sleep. In the end, the
    corporate goons repaid my many years of service with
    a pink slip and sent my job to India.
    Note here for you younger guys. Don't make that mistake.
    It takes a toll. Don't put up with it.
    txcoastal1 Posts: 13,520
    If the meds are kicking your behind, choose a different one. Do not take combo pills that have Hydrochlorothiazide. They will dehydrate you daily. Summer time NO NO!!
    I also pill cut 1/2's, test and regulate my own blood pressure. Exercise even a good walk every other day helps regulate.
  • sucks2beme
    Been drinking a ton of water. Was doing a lot of walking and exercise.
    I have lost weight too. Even more now under the new diet. Cut out caffeine
    as well. I have had to cut back on walking the last couple of weeks due
    to the heat.
    At this point, had no choice but go with the doctor's guidance.
    The doctor will most likely cut me back on the meds this month
    when I go in for my appointment. At least that was the plan.
    My vision needs to get better. I have to zoom in the tablet to
    read or post things. I let the wife do the driving for now.
    I'm just glad I didn't have a heart attack or stroke. Too many
    Of my former co-workers had this happen.
  • aprazer402
    aprazer402 Posts: 3,463
    @sucks2beme
    I hope you get better real soon!!!!
    I fell hard on a sidewalk last December. Saw a large floater within an hour. Got in to a Retina specialist early the next morning. During the same appt. the Dr. lasered around two small holes in my retina. I was seeing flashes in my peripheral vision.
    I went back this Febr., he said it healed well where he lasered. He said there was some blood inside the eye in the bottom that would be reabsorbed in time.
    Next appt. was May. In May he said the blood was coming from a very small vessel and that's what is causing occasional floaters and slightly hazey vision in the one eye. He said it's 50/50 the small bleed will resolve on it's own. If it does not stop, he said a Vitrectomy would be needed to remove the vitreous fluid/gel inside the eye and go in and cauterize the vessel. Outpatient about one hour, 95% success rate.
    He will have to inject a gas bubble into my eye as my body will not replace the vitreous gel immediately. The gas bubble is to place pressure against the retina while my body makes replacement vitreous fluid/gel.
    THIS IS THE BAD: He said I will have to lay on my side 50 minutes of every hour! 24 hours a day, FOR 5-6 WEEKS! Also he said after a Vitrectomy a cataract will usually appear in the eye in 1-3 years.
    My next appointment is next Wednesday July 12th!
    audioluvr Posts: 6,065
    edited July 2023
    I've heard weed helps everything.
    Edit: My Dad has the shots in his eyes. He says it's painless
  • jbreezy5
    jbreezy5 Posts: 1,141
    Praying for dude’s with these eye struggles. Sounds awful. Sorry you’re going through it!
  • sucks2beme
    At least there are treatments. So many other things in life
    aren't fixable. In a way, it saved my life. Most people wouldn't
    survive with the blood pressure level I had.
    Good luck Aprazer, I hope everything works out for you.
  • Willow
    Willow Posts: 11,360
    First off, I'm sorry to hear of your health issues, def. not a good time from what it sounds like. When drinking water, you may wish to add salt and magnesium to help rehydrate you properly. Water is good on its own but it is missing the minerals your body needs. Hope you and Aprazer get better soon and make a great and healthy recovery.
  • Milito
    Milito Posts: 2,003
    Also hope both of you have a quick recovery and feel better soon.
    I also had my eye lasered about 5-6 years ago due to was seeing flashes. No problems since.
  • motorstereo
    motorstereo Posts: 2,425
    Get those eyes checked, and do whatever the doctor recommends. In my case I've struggled with poor vision all my life. Diagnosed with glaucoma 30 years ago, laser treatments, laser vision correction, stents, trabs, pills, drops and cataract removals last year that didn't turn out so well. I would give anything I own for decent vision. But I am grateful that I live in modern times as I would've been completely blind in my 40's had I lived before modern medicine that can diagnose and control many vision problems.
    F1nut Posts: 52,381
    I hope you guys with the eye problems get things sorted out quickly.
  • sucks2beme
    Thanks. I do know it's not gonna be OK right away.
    Doctor warned me about that it will get a bit worse
    from the injections short term. I appreciate the support
    from my fellow Polkforum members.
  • bcwsrt
    bcwsrt Posts: 2,676
    Wow! That's a huge turnaround from your earlier post! Awesome!
    Hoping for an equally good report from @sucks2beme soon!
    Brian
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,102
    I'll put my name into this "pot". I am commenting to remind everyone who reads this to not delay when an eye problem occurs.
    I had 20-20 vision until I was about 52 years old. I was driving alone on a Friday evening to North Myrtle Beach from Atlanta to meet several friends to play golf for the weekend. It was my first trip to Myrtle Beach, and before phones with maps. I was confused with some of the roads once I left I-95, and I pulled out a folded map to help. I realized I could not read the map at night. Got my first glasses shortly after that.
    About 10-12 years later, I woke one morning and all I saw from my left eye was flashes of light. I knew it was serious and contacted my ophthalmologist. The next day, I had laser surgery for a tear in the retina. I was told that within 1-2 days the tear would have become a detached retina which requires hospitalization and surgery.
    Since the laser surgery, I have developed floaters in both eyes with the left eye having the most and worst ones. I have posted on Polk re my cataract surgery for both eyes, and the surgery returned my vision to almost 20-20. I do wear reading glasses. My father suffered from Age-Related Macular Degeneration and the doctor is trying to prevent this terrible disease in my eyes.
    At this time, my doctor has me taking he AREDS2 (Age-Related Eye Disease Studies) formula of supplements developed by the National Eye Institute. There is one exception to the suggested dosages contained in the formula. I am taking 25 mgs extra of Lutein.
    One thing that I have noticed is my vision is more impacted by the floaters (and my tinnitus is worse) when sinus pressure and congestion is an issue which is usually caused by an allergy.
    Note: I have a yearly checkup with my ophthalmologist.
    https://www.nei.nih.gov/research/clinical-trials/age-related-eye-disease-studies-aredsareds2/aredsareds2-frequently-asked-questions
    These are the supplements I am taking.
    Harry / Marietta GA
  • Emlyn
    Emlyn Posts: 4,901
    My optometrist recommended I start taking Macuhealth a couple years ago in my mid-50s. He spotted a few small deposits called drusen in the central parts of my retinas. Drusen are deposits of waste material that the eyes don't clear over time. These things come and go over a lifetime but eventually they can accumulate and cause central visiion loss. I didn't really notice any problems myself.
    On my last checkup the drusen had reduced but I also notice that I no longer experience any glare when driving at night. One pill a day. The optometrist did say that he's starting to recommend that everyone consider using a lutein supplement given modern diets don't provide most people with enough nutrients for proper eye health. Eating spinach at least once a week also helps.
    https://www.amazon.com/Macuhealth-MacuHealth-90ct/dp/B00CD8WAKK?pd_rd_w=1aEYL&content-id=amzn1.sym.c15e5526-d433-4ac0-a393-a3f3f7218fab&pf_rd_p=c15e5526-d433-4ac0-a393-a3f3f7218fab&pf_rd_r=Z07NHNGEC0943YQVEST6&pd_rd_wg=JPreI&pd_rd_r=f2ad5682-6587-4196-b4e7-ae87c84ff6dd&pd_rd_i=B00CD8WAKK&psc=1&ref_=pd_bap_d_grid_rp_0_1_ec_t
    pitdogg2 Posts: 27,883
    All that stuff is in my daily vitiman for men over 50. Glad to hear it is all helping.
  • schwarcw
    schwarcw Posts: 7,360
    aprazer402 wrote: »
    @sucks2beme
    I experienced exactly what you described. I had a detached retina in the first days of the Covid lockdowns and had emergency eye surgery. This major university hospital was basically closed. Nurses and Security met me wearing hazmet suits. Crazy times! The recovery from this surgery is hard but it works. I regained the vast majority of my eyesight. Good luck!
    Carl
  • seeclear
    seeclear Posts: 1,244
    Harry, just so you know, that nature made supplement you are taking is intended to be taked IN ADDITION TO a regular daily multivitamin. So if you're not taking one of those too you are not getting the full complement of vitamin/supplement found to be effective in the Age Related Eye Disease 2 study. FWIW.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • BlueBirdMusic
    @seeclear, Thanks I didn't know that.
    Harry / Marietta GA
  • shirakresch
    Wow! that’s a lot to go through. Thanks for sharing it so openly. It's wild how something like blurry vision can become a huge red flag for something bigger. Sounds like you’ve got a solid care team, though, and that’s half the battle. Those eye shots? Major respect — that takes some serious guts.
    And yeah, blood pressure can be sneaky like that. No symptoms until suddenly, boom — it’s a whole situation. Hopefully now that things are getting under control, you’ll get some relief on the meds too.
    And 100% agree: aging isn’t for wimps. But you’re handling it like a champ.
    If you’re ever looking into vision support during recovery, michigancontactlens.com does amazing work with specialty lenses and dry eye treatment too. Might be a comfort down the line.
    Also, solid Jefferson quote to top it off
