New system setup help
I just bought the following to dip my toes back in to complete 5.1+ setup. I had some experience in HT back in the day when I worked for Best Buy HT 15+ years ago, and a lot of things somewhat changed.
Setup:
Avrs760
Xt60
Xt30
Xt90
Rockville slim surrounds
Rockville 10" sub
I know the rockvilles aren't the greatest, but they're rears so they're not going to do a lot of heavy lifting, and to me bass sounds the same. I could've done some Polk rears in ceiling, but I didn't want to cut any holes in my finished basement.
I'm trying to see what crossover settings I should do per speaker. I've read that 80z is the standard, but I want to get the most out of the system.
Xt60:
Frequency response-38hz-40khz
Frequency response(-3db)43hz-26khz
Xt30:
Frequency response-55hz-40khz
Frequency response(-3db)77hz-26khz
Xt90:
Frequency response-94hz-22khz
Frequency response(-3db)164hz-17khz
Rockville slim surrounds:
Frequency response-100hz-20khz
Cross over frequency-100hz
Rockville 10" sub:
Amplifier: Class D
Woofer Impedance: 4 Ohm
Signal to noise ratio: 85 dB (Maximum output with THD+1<1%, A-weight)
THD: 1%
INPUT sensitivity: 88dB +/- 2dB
Frequency Response: 20 Hz - 200 Hz
600 Watts peak output
300 Watts RMS output
Setup:
Avrs760
Xt60
Xt30
Xt90
Rockville 10" sub
Xt60:
Xt30:
Xt90:
Rockville 10" sub:
Amplifier: Class D
THD: 1%
Overall, you’re going to listen with your own ears to make the best choices
But you can try these settings
Your center at 80
XT90’s at 100
XT60’s at 60…this may help provide a fuller bass response until you get a better HT sub2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Congrats on the new setup. Enjoy!Things work out best for those who make the best of the way things work out.-John Wooden
