Can I fix a mark Levinson 33 Monoblock thread
124»
    F1nut Posts: 51,951
    It truly is a overly complex piece of equipment
    Fixed it for you 🤑
    VR3 Posts: 29,535
    edited April 2025
    Lol!
    I found a handful of suspect parts that seem to be associated with some nearby op amps (which are in line with those resistors)
    Post edited by VR3 on
    VR3 Posts: 29,535
    edited April 2025
    Some of the guys at diyaudio have changed out the 555 timer to a lower noise ICM7555IPAZ, I guess it's the heart of the oscillator so to speak.
    I sourced a military version of the ad705aq so I ordered 20 (minimum order). This opamp is used in a few other places in the amp as well.
    There is also a new version replacement of another ic I will go ahead and replace.
    I plan to rebuild the control board before I order anymore regenerator parts.
    The fun continues!
    SCompRacer Posts: 9,121
    edited April 2025
    I can't work with pdf schematics on the 'putie anymore. I go to FedEx Office, print them in large format (one was 24"x36"), and highlight the circuit.
    Didn't Ken post an inexpensive op amp tester a while back?
    VR3 Posts: 29,535
    I will have to see if I can source an inexpensive op amp tester.
    I have been looking cross eyed at cap meters that go from 10 PF to 60,000uf but my eyes went a little cross eyed pricing it out. My current software only goes from .01uf to 10,000uf.
    I honestly see the appeal to printing out these schematics, theres alot of information to digest here.
    I did start a One Note document I have been building as I go here loading in the schematics and paperwork per board and documenting parts I ordered for future reference//// next owner if I ever decide to sell.
    edited April 2025
    Thats good documenting your repairs/upgrades. I've done that and pass it on.
    Sometimes the quality of downloaded scanned pdf manuals and schematics are poor. Sometimes there are more than one out there and are better, so I'll shop around.
    Originals can be scarce and pricey. I lucked out and got an original service manual and schematic off ebay for my A-6300 for 20 bucks shipped. I've seen them sell for $100. The DL wasn't too bad but the original pops with voltage readings in color.
    I've read there are some fee based companies selling high quality copies but didn't save the link.
    Toolfan66 Posts: 18,161
    Some of you guys are truly mad men, I love watching stuff unfold as you guys do work like this, I for one wouldn’t get this deep, I probably would be the one to touch the wrong area, and knock myself to the ground. LOL!!
    Great thread Trey..
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,295
    edited April 2025
    This one worked fine for me:
    https://www.amazon.com/dp/B09SVL31V5?ref=ppx_yo2ov_dt_b_fed_asin_title
    But looks like it's not available currently, sorry. I'd be happy to send mine to you if you'd like.
    VR3 Posts: 29,535
    I ordered this, should be here in a few weeks
    treitz3 Posts: 20,083
    What in Scooter's creation is that?
    VR3 Posts: 29,535
    Op amp tester
    VR3 Posts: 29,535
    edited July 2025
    So all caps replaced... Electrolytic, film, ceramic.
    Replaced all relays
    Replaced both op amps... The old ones measured good on the tester but I ordered 75 new ones so... Why not replace!
    Replaced around 40 resistors. I wanted to replace one pair but no one carried an equivalent quality. The resistor still measures perfect but just looks like it has been hot in the past. All of the resistors I installed are further from the board as well.
    Finally catching up to where I can tackle this again! Should be able to knock some out this week for sure! 😁
    F1nut Posts: 51,951
    Better you than me...lol
    VR3 Posts: 29,535
    edited July 2025
    Lol, i honestly find it somewhat therapeutic... Strangely enough
    Obviously it would be nice that it worked once I'm done hahahhahhahahhaha but I've learned alot working on it so far and gathered tools that will be helpful for future projects.
    The biggest investment so far have been Desoldering tips... Jeebus those bad boys are expensive but you definitely have to have the right size for different size pads, no question!
  • skipshot12
    skipshot12 Posts: 2,091
    As bad as doing a KSA-250, more patience than most.... nice.
  • invalid
    invalid Posts: 1,519
    skipshot12 wrote: »
    It's looks far more complex than a ksa 250. I'm not looking forward to fixing my ksa 300s, which is more complex than the ksa 250 also.
  • skipshot12
    Wow, you deal around me.
  • skrol
    skrol Posts: 3,460
    VR3 wrote: »
    How about this guy who was never soldered from the factory
    I found similar when I did the XOs in my RTA11TLs. On one of the XOs the 12uF electrolytic cap that is paralleled with the 1.5ohm resistor was looped around the leads of the resistor but not soldered.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    Dang...
    billbillw Posts: 7,738
    That's what you call Friday afternoon production!
