Polk SDA 1 ...?
dgozalie
Hello all
someone offer me this...
how much is the market value right now ?
and about the tweeter... is it the good one ?
Yes SDA 1
Do you have the SDA cable?
There are better tweeters.
You cannot sell them here, market is all over the place. Those are not the most desirable SDA's -
thanks for the advice... so what is the most desireable SDA ?
The last, 5th generation are held to high regards. They are vastly different (better) from the first generation.
I will say, I've heard highly hot rodded first gen sda srs and hot rodded 1.2tl on the same day and I can say confidently they both can sound very very good in their own way- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
